Results 1 to 6 of 6
Thread: cabin trunk gelcoat
  1. #1
    Principal Partner steven's Avatar
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    383
    cabin trunk gelcoat
    On the front of the trunk cabin, the gelcoat has worn through. Looks green-ish/grey-ish.
    Is there a pain, coating or technique that can be used to restore ?
    --Steve
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	deck gelcoat close up 2019-0522 (1).jpg
ID:	27036   Click image for larger version.
Name:	deck gelcoat view2  2019-0522.jpg
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  2. #2
    Join Date
    Apr 2006
    Location
    Nanaimo, British Columbia, Canada on Vancouver Island
    Posts
    1,944
    Hi Steve,
    Is this the only area where the gelcoat has worn away, or are your pics just one of many areas that have worn?
    If it's only that area and the other gelcoat is still good, it would be a fairly easy fix. If it's worn and faded all over, then painting might be the easier solution. Let us know so the advice can be tailored to your needs.
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,129
    Blog Entries
    78
    A lot of us have painted our reverse transoms, which get a lot of sun over the years. The transom is forgiving of color variation from the gel coat because it's a separate plane.
    The issue everywhere else is that the color won't exactly match. That's true of gel coat or Awlgrip (which I used on the transom).
    However, you could always paint your coach roof in a frame of painter's tape, intentionally making the new-coated area a rectangle or ellipse or whatever you like.
    Then, in a fit of elegance, place in it the yacht name decal -- as if the area was intended for that all along.
    Also: some free-lance boat painters will paint the whole deck for not too much dough, right in the slip. I'd never take that on myself, but we have a guy here who has brought back many old boats to really shiny perfection.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  4. #4
    Join Date
    Oct 2005
    Location
    Annapolis
    Posts
    383
    it's just the fwd surface of the coach roof. The rest is fine.
    (Not clear why this went. Maybe northern exposure in the slip for multiple winters or something. But it appeared suddenly, that is, I only noticed it a few months ago.
    An easy fix would be great.
    --Steve
    Steve and Paula
    Indigo E35-2 #446
    Annapolis
  5. #5
    Join Date
    Jan 2019
    Location
    Annapolis area
    Posts
    141
    Can you tape off the area as Christian wrote and simply add gelcoat?
    If so, this is one of a series of (iirc) about 7 videos and all are worth watching:
    https://www.boatworkstoday.com/videos/applying-gelcoat/
  6. #6
    Principal Partner Mark F's Avatar
    Join Date
    Sep 2003
    Location
    Felton CA
    Posts
    985
    Blog Entries
    5
    Plus one on the Boatworks tutorials...
    Lotus Flower
    1976 E27
    Electric Inboard
    Santa Cruz CA
Similar Threads
  1. E23-2 CB Trunk Boot Template
    By Tempest in forum Maintenance & Mechanical
    Last Post: 07-24-2018, 10:16 PM
  2. E23 swing keel centerboard trunk leak
    By Timothy3821 in forum Maintenance & Mechanical
    Last Post: 07-24-2018, 10:08 PM
  3. gelcoat
    By Mark F in forum Maintenance & Mechanical
    Last Post: 12-12-2007, 08:52 AM
  4. gelcoat or paint
    By bob smith in forum Maintenance & Mechanical
    Last Post: 10-05-2006, 09:07 PM
  5. Gelcoat Revival
    By sastephens in forum Maintenance & Mechanical
    Last Post: 02-06-2005, 08:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
