[E32-3] Adding new battery bank, installing monitor
Geoff W.
So I started this thread when I got my boat: http://www.ericsonyachts.org/infoexchange/showthread.php?16099-E32-3-Installing-Victron-BMV-700
But now that it's getting summer-y, and I have lubber cruise-mates coming aboard with CPAP machines and various electrical demands on a week long cruise, and given that their comfort is pretty important to me, I figure it's time I go through with upgrading my battery bank and getting the Victron installed.
The scope of this project looks like this:
  • Remove two current Group 24 deep cycle Napa Auto Parts batteries
  • Install two new 6V AGMs in SERIES as house bank (edited)
    • Trojan T105-AGMs
    • Install these under aft-most port settee
    • Install battery box?
  • Install new 12V Group 24 starter battery as backup
    • Installed in current battery box
  • Install new Battery Charger? Currently have a Guest 20A dual bank charger.
  • Install Victron battery monitor
  • Install Negative Bus Bar along engine stringer a la Christian's and Maine Sail's setups I've seen elsewhere.
I think there's plenty here to keep me busy, and I'll have to learn where a lot of negatives are grounded, run new wires, and so on. I'm thinking something like this picture:
Note that locations of the bus bars / shunts are more for the logical flow rather than where I think they'll physically end up. My biggest questions right now are around the wires themselves - do I somehow need to try and pre-measure lengths of wire so I can figure out what lengths to get? Do I need special tools to make custom lengths of heavy gauge wiring, or is this best shipped out to a pro?
Also, is a battery box going to be highly recommended if I have 2 6V batteries under the settee? I can just squeeze the two T105's in per virtual measurements, but not sure I can fit a prefab box.
I'd think, especially if you are putting lead acid batteries in the salon, a closed battery box, vented to the outside is recommended. But you can probably fabricate one in place to fit your space. IIRC, there is an example in one of the yacht maintenance bibles.
It may be time to spin the dial again on researching lithium-iron phosphate batteries. The up-front cost is still a shocker, but cost per usable amp-hour may come out way ahead. And it sure would be nice to get all that weight off the boat. And no battery box.
Like you, I have long planned to install a new house bank at the end of the current re-fit. Still haven't decided if I can afford LiFePO4. Or if the ones that I might be able to afford would work correctly. Not this weeks problem though.
fool
Hello Geoff,
Making cables is extremely gratifying and easy to do after you do your first one. Both West Marine and Beacon Marine where I am have crimping tools where they are handy and will allow you to do your own cables on site. Beacon even has a heat gun to do the heat shrink insulation on the ends, check with your local chandlery. If they have the stuff I highly recommend giving at least one cable a go, the rest will follow. (You'll keep your first cable on the saloon table for a week to show to everyone who happens to be within 500 yards of the boat, I know I did.)
https://marinehowto.com/making-your-own-battery-cables/
I also did the (shunted) Victron 712 when upgrading to LiFePO4 batteries. It wasn't that difficult to add a bus bar and made all the negative connections required much simpler. The 712 has a built in bluetooth connection to a phone app which makes monitoring the system much easier too. Most of your negative connections probably terminate at the battery anyway, so it shouldn't be too difficult to manage.
Toddster - LiFePO4 is the way to go if you can get over the immediate pricing issues. I'd do it again in a heartbeat without a second thought. When comparing batteries take a close look at the BMS (Battery Management System - https://battlebornbatteries.com/what-is-a-bms/).
The quickest way to kill LiFePo4 is to over charge them or to deplete them 100%. A good BMS will prevent over charging and put depleted batteries into a sleep mode for self protection. The Victron shunt can also be set to close at a programmable voltages. LiFePO4 are super happy taking on huge amounts of current to get to 100% charge and do not need a maintenance charge to keep them happy. They will not self discharge overtime if left in storage by more than a few percentages, no trickle or Float charge needed.
I highly recommend Battle Born Batteries (aka Dragonfly) for quality, competitive pricing, easily accessible information, customer service, and built in BMS. I did a ton of shopping around when it came to replacing my old West Marine (Deka) AGM batteries - researching and comparing Lead Acid/AGM/Gel/Carbon Foam/and LiFePo4.
Basically there are a handful of lead acid battery factories that everyone puts their own labels on, Deka - East Penn, Trojan, NRG, YUASA, NorthStar and a few others, each with their own reputation mostly around recovery from sulfation. The quickest way to kill lead acid (AGM, Gel) is to undercharge them creating a Partial State of Charge (PSOC) which in turn creates sulfation. Your battery charger (or solar regulator) equilization mode is designed to compensate for sulfation.
Lead acid (AGM, Gel) should also not be depleted below 50% of their AH ratings. LiFePO4 can be depleted to 10% without any reduction of total capacity or battery life. I constantly checked in on my SOC (State of Charge) with the old AGMs using a Balmar Smartguage to monitor and to prevent PSOC. (The Balmar great piece of equipment, no shunt required, free to a good home for postage as it won't work on LiFePO4,) With the new batteries I rarely give this a second thought and find myself trying to discharge them enough to give the solar panels something to do in their spare time.
Never thought I'd make the leap to Lithium Iron, really happy I did, wouldn't go back despite the initial cost.
Geoff W.
I read something saying you can run AGMs down to about 80% without killing them too badly? Is that not true?
Tin Kicker
The difference between 20A and 30A will depend on how deeply you discharge the batteries and how long the boat will have at the dock to recharge them. You'll need to do the math for your own conditions.
Or save up your boat-bucks for a combination inverter-charger... Victron make a nice one that plays well with their other toys.
debonAir
Yes, that's a primary advantage of AGM vs FLA. But it gets tricky with the battery's actual ratings. AGMs are just better in general at deeper discharges, But keep in mind that battery life is complex combination of cycle count, depth-of-discharge, rate-of-discharge (and rate-of-charge) and temperature, float voltage (the voltage charger is kept at to trickle when fully charged), etc. For me, AGM's primary advantage is not leaking acid, then comes depth of discharge. If you're routinely going to 80% into your batteries capacity I'd suggest getting a larger or more battery. If cost isn't a big obstacle, getting a LiFePo drop-in (about $1200) is way better all around.
fool
You can discharge to 80% however...
The deeper the discharge the fewer cycles you'll get out of your battery life. Let's say you discharge your battery bank to 80% and get somewhere around 1000 cycles. The same bank discharged to 50% would last roughly a third longer or about 1500 cycles. I'm fudging the math, but you get the idea. The batteries will also degrade slightly over time. A battery "life" has ended when the battery has degraded to about 50% of the original AH rating.
My West Marine Group 31 bank (Deka - East Penn) lasted about three years of daily use, meeting 95% of my energy needs, until their performance prompted replacement. There was still some life left, but not the same life as when we started. By my best guess I'd say I was getting about 60% to 65% of the original amp hours.
To discharge less get more AH's to meet your needs. There are plenty of energy use calculators on the interweb to assist.
Max
fool
Another question:
I will likely want to upgrade to a 30A if I'm going to a bigger bank, right?
Not sure how critical an upgrade this is, though.
Not critical. How quickly do you need to get your batteries back up to full charge?
Let's go to a stadium event (rock concert or ball game) with general seating. It'll take longer for the stadium to fill up if they only open 20 gates than if they had 30 gates open. At first the stadium will start to fill pretty quickly, and then slow down as the seats get taken. Just before the start of the event finding a seat gets more difficult and takes longer. This is a pretty good analogy for charging batteries that'll go pretty quickly to from 50% to 85-95% capacity, and then take just as long to get in that last 10%.
My "30 amp" charger is wired into each of three batteries (as banks) separately, giving each a load of 10 amps and not 30 per battery or bank. The Promariner "[FONT=&amp]automatically distributes 100% of available charging power to any combination of batteries in as many as three banks[/FONT]". So if you wire for a 100 AH bank and a 200 AH bank, it should open 10 gates for one stadium event and 20 gates for the other. The data sheet for the Guest on Board states it'll put 10 amps each into two banks, so 10 gates per event no matter how big the stadium.
I didn't review the "stages" for each charger (bulk, absorption, float, or equalization). The explanation for the first three is here https://www.batterystuff.com/blog/3-stages-of-smart-chargers.html. Equalization, which if I understand correctly is programmed to run every 20 days or so on some chargers and overcharges the batteries to reduce the amount of sulfation. (Don't use or need this feature on LiFePO4).
Clear as mud? I thought so...
Max
fool
Well said.
LiFePO4 Batteries from Battle Born are currently running $950 for a 100 AH group 27. A similar battery from Renogy is currently $899, both appear to have similar BMS's installed in the battery.
The weight of Lead Acid (AGM, Gel) is the lead inside, the heavier the better. Not an issue with Lithium Iron.
nquigley
Looking at your diagram ... how to you plan to traverse the open area between the chart table furniture and the place where the present batteries are located? (how to you plan to hold down and 'contain' the cables?). I plan to bring cables from a new anchor windlass under the port settee, and across to the OEM battery location, but can't work out how best to bridge that gap.
Tin Kicker
nquiggly -
I just ran wires to a new 115 VAC outlet beneath the chart table and can answer that. There is a hole in the liner which can be accessed from behind the slide-out beneath the chart table. Take out the slide-out (4 hinge screws) which is beneath the chart tubes. Then open the round access panel that your left butt cheek sits above when at the chart table. You can slide a wire between the two, then aft to the batteries by following the battery cables.
Geoff W -
I think that your batteries under the settee won't meet the ABYC requirements for venting and containment.
I've been thinking also about where to put additional battery(ies?) and am thinking about a box which can be lowered into the starboard cockpit locker. A pulley/block temporarily hanging from the boom could provide the lifting muscle when needed. Obviously, the battery cables will need to be long but the answer to that is simply a heavier AWG.
Geoff W.
nquiggly -
This is why these forums rule. I didn't actually have an answer to nquiggly's question, but was trying to figure out an answer that sounds like I have a plan.
Now I'm going back and forth on the Lithium battery issue. Sure seems like a nice upgrade. If I got two Group 24's, which seem to run about 75 Ah each, I wouldn't have to do a ton of extra work....seems like it would literally just be a drop-in replacement, with the option of a bigger charger. Going with the 6V's would give me about 100 Ah at about 1/2 the cost, but also at 2x the weight. Where's a windfall when you need it?
Do you know what specific reqs would be missing? The OEM battery box is still in the saloon, and not vented anywhere in particular as far as I can tell. Plus, AGM batteries don't off-gas, right?
Tin Kicker
You can Google the battery box rules but basically:
Enclosed box. Important for all three types of battery.
Batteries unable to move
Vented - AGM are still required to be in a vented space.
Positive terminals covered
The OEM box has no venting but you could argue that is how the OEM designed the boat. Putting the batteries beneath the settee would lack both venting and an enclosed box, so that's why I think it would fail a survey.
Baslin
  • Install two new 6V AGMs in parallel as house bank
    • Trojan T105-AGMs
You will want to wire the 6 Volt Batteries in Series. Wiring them in parallel will keep the same 6 Volts.
Geoff W.
Hi all,
As usual with me, this project has scoped down to be more affordable and actually get done by my cruise. I started going down lithium repowers, adding solar, etc, when really all I need to accomplish here is upping my house bank size and installing a battery monitor.
Then I saw the West Marine Group 24 AGMs were on sale, so that decision sort of made itself. They were cheap enough that I won't be too reticent to go through with the rest of the overhaul in a year or two, when it's time.
As such I'll now be doing the following:
- 2 Group 24s AGMs in parallel in the OEM Battery Box (House Bank)
- 1 Group 24 AGM in a mounted battery box under the port, aft, settee (Start Bank)
I drew this diagram up to make sure I understood what I was doing here, and I think it's going to end up being pretty simple, all things considered. Mostly it'll be running new wires and measuring runs accurately, which I anticipate messing up a few times.
Are there any glaring issues here?
Hagar2sail
We are just going through an overhaul of our battery management / charge management systems on our boat. Looking at your schematic it seems like a KISS setup that will work. My only comment is one born out of my own issues. I would think of putting an ACR in to join the house and engine battery for charging. I would then send the alternator to the house bank. Using the start wire for transmission back to the batteries from the alternator could cause relay chatter. Wiring the alternator to the batteries separate prevents ever damaging your alternator from switching the 1-2-both switch while the engine is running. By using an ACR you are preparing yourself for solar, as very few (I haven’t seen any yet) controllers are multi-output. We had this issue on Rhumb Ration. The PO had installed a multi-channel shore power charger, but we had no way of charging all the batteries with our new solar setup we installed unless we kept the battery switch on at all times (not so good).
Good luck!
KISS: I lived on the 32-3 all summer, Hawaii and back, effectively using only one Group 27 flooded battery discharged daily to 60 percent and recharged to 80 percent (100 amp alternator). No hardship.
