Page 1 of 4 1234 LastLast
Results 1 to 15 of 58
Thread: Survey: E35-3 Propane Control Panel Location
  1. #1
    Contributing Partner MarineCityBrian's Avatar
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Survey: Where is the Propane Control Panel located in your boat? (in particular E35-3)
    Background:
    I am in the process of installing a Seaward/Hillerange Propane 3-burner stove in my E35-3 (the Galley Maid pressurized alcohol unit has been removed for some time, and I came across a fair price for this propane unit which came with tank, panel, sniffer, line, regulator, valve; all parts required for a safe installation).
    The location of most components are given (propane tank, line, stove, etc) but I'd like to find out where other owners of E35-3s (or E38s, which I understand have a similar galley area) have their Propane Panel located. The wiring diagram in the E35-3 manual indicates wiring for a propane switch being located near the trash door and the pivoting dish compartment on the aft wall of the galley. This is indicated with the red arrow and box below (which reads "LPG Solenoid Switch Panel").
    Click image for larger version.
Name:	Propane Panel Location.jpg
    I've also indicated where I think the ideal location for it might be (just aft of the stove opening) with the blue letter "A". I believe this to be hollow within (or potentially filled with whatever foam they used to insulate the icebox) since there is space between the icebox inner wall and that surface, it's within relative proximity to the indicated factory wiring for making a connection, and has suitable area to install the particular panel that came with my stove. I can say that there is NOT enough space to mount the average Propane Panel in the indicated location on the Ericson wiring diagram (there's probably only a couple inches between the trash door and the dish locker, and my panel is larger than 2" wide).
    I have also seen several located over by the DC and AC panels on the port side by the nav station.
    SO..... I'd really appreciate input/thoughts/pros/cons of your propane panel installation.
    Thanks!
    Brian Ross
    1983 Ericson 35-3 Hull #119
    "Moonshadow"
    Universal M-25
  2. #2
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,041
    Blog Entries
    78
    Here's my factory setup:
Name:	1-IMG_1659 - Copy.JPG
    I'm embarrassed not to actually know if the thingamabob in Pic #2 is the sensor. It seems a little high for sniffing propane, no? Anyway, it's something. Maybe I will learn something about my own boat today.
Name:	1-IMG_4712 - Copy.JPG
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  3. #3
    Curator of Broken Parts toddster's Avatar
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,638
    Blog Entries
    50
    I believe the sensor ought to be down near the cabin sole level...
    Probably ought to be tested occasionally too.
    While I donít have a E35, and I installed the thing myself, (there was a hole there that needed filling) Iíve noticed that I lean across the stove to turn on/off the solenoid. That doesnít seem right...
    s/v arcturus E29 #134
  4. #4
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Ah! Perhaps ABOVE the tilting dish storage locker might be an option...this should be underneath the backrest on the side of the cockpit forward of where the winches mount, and accessible by the starboard cockpit locker....but also a decent and awkward reach while cooking (the larger size of your E38 may help here; my recollection is that it would be pretty cramped/awkward to reach that, but I'll give it a try the next time I'm on the boat).
    Agreed on that 'sniffer' location being a bit high to detect propane... The person I got the stove from had the sniffer installed in the engine compartment. The manual recommends below the stove, but away from an area that might get kicked. I was hoping to poke it through a drilled hole aft of the storage door beneath the stove.
    Thanks so much for your input!
    Brian Ross
    "Moonshadow"
    Universal M-25
  5. #5
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Quote Originally Posted by toddster View Post
    Agreed on not wanting to have to reach over the stove to turn on/off the solenoid! Very good point! The location just below the countertop aft of the stove is sounding more attractive (within easy reach while cooking) although I still fear access with wiring...
    Brian Ross
    "Moonshadow"
    Universal M-25
  6. #6
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,041
    Blog Entries
    78
    Don't have to reach across the stove. Across the sink.
  7. #7
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Quote Originally Posted by Christian Williams View Post
    True. Toddster's must be in a different location.
    I'll give the 'above dish storage area' location a try tomorrow.
    Brian Ross
    "Moonshadow"
    Universal M-25
  8. #8
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,638
    Blog Entries
    50
    It's essentially the same location, but everything is just smaller and closer-together on my boat. Alternatively, some people may be larger...
  9. #9
    Join Date
    Apr 2014
    Location
    San Francisco
    Posts
    133
    The solenoid switch / sensor panel is in the location Christian indicated above the tilt out door. A little annoying as this would be a good position for the wheel-pilot sensor.
    The propane sensor is a small puck underneath the stove.
    Mike Field
    "Jenny" E35-3 #251
    San Francisco
  10. #10
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,041
    Blog Entries
    78
    Now I have to figure out what they mystery thing is on my bulkhead.
    There's a part of my own boat I don't understand?
    Inconceivable!
  11. #11
    Contributing Partner kiwisailor's Avatar
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    142
    Blog Entries
    21
    Quote Originally Posted by MarineCityBrian View Post
    Thanks!
    I don't have a sniffer in my setup....I use by nose and always turn the propane off at the tank after use. But I have the solenoid switch located between the cupboards and under the light....see picture below.
    Most other boats I have seen have the solenoid switch that includes the sensor installed on the cabinet face next to the top cutlery draw. Then you can easily feed the sensor wire from the bilge to the solenoid sensor. In my boat this cabinet face has my Marineair AC control panel. There seems to be enough space behind the panel and between the cutlery draw to install wiring etc.
    Just to add the solenoid switch is convenience being near the stove as your boat should also have a "Stove" circuit breaker on the DC panel. You can always turn the propane solenoid off there too.
ID:	26925Click image for larger version.
    Sherene & Mike Taniwha
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
  12. #12
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Quote Originally Posted by kiwisailor View Post
    For me, to add the Propane Panel on the face adjacent the cutlery drawer would interfere with the drawer, as my panel is fairly deep. The A/C controls (as you have them positioned) are probably the perfect depth to not interfere with the drawer. My A/C controls were located in place of one of the "chart tubes" beneath the Nav table, but I like your location - that's a great place for them.
    In your larger 38 there's a locker aft of the stove, whereas on my smaller 35 there's just a panel there. It also looks like the length of the 38 allows a few more inches of space on that panel, as it appears wider than mine.
    I'd be interested in placing the Propane Panel here, and the fact that your 38 has a locker there leads me to believe there might actually be hollow space behind it. Mine has no locker (I've X-d yours out to attempt to simulate my arragement) but the panel is slightly narrower:
Name:	Panel Location Possibility.JPG
    Also (and this is why I love seeing other boat configurations) in the corner where you have a locker above the countertop, my boat has a wine rack...
    Brian Ross
    "Moonshadow"
    Universal M-25
  13. #13
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    142
    Blog Entries
    21
    That would be a good location. The previous owner of my boat opened up this area that you have marked. It's full of foam about 3 to 4 inches deep. There was also some additional bracing for the plywood teak veneer panel and to hold the ice box near the top. The issue I see is then being able to get wires to this location, you will have to some how punch a hole through the foam from the top to the bottom near the hull to pull the wires.
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
  14. #14
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    1,270
    Blog Entries
    23
    Microphone for hands-free phonecalls?
    Secret advanced copy of Alexa-for-sailboats?
    Doorbell camera?
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  15. #15
    Join Date
    Feb 2014
    Location
    Marine City, MI
    Posts
    118
    Great to know - So you had an endeavorous previous owner who ADDED that compartment (I was hopeful this was from the factory and gave hope that it might be at least partially hollow beneath...). I will say that's not a bad idea, as I currently have a leaky icebox drain in my main icebox, and I see no good way to get to the bottom of that short of cutting through that area... Perhaps that's what your PO did? Do you know if you can see the icebox drain by opening that compartment? Or are you saying there's no actual storage there, just a panel which covers the foam directly beneath it?
    Brian Ross
    "Moonshadow"
    Universal M-25
Similar Threads
  1. Propane Tank - Debating Location
    By adam in forum Maintenance & Mechanical
    Last Post: 01-02-2019, 01:22 PM
  2. Newtec propane control
    By tmjkelley in forum Maintenance & Mechanical
    Last Post: 09-04-2017, 07:28 PM
  3. Cockpit Control Panel
    By Tbacon in forum Maintenance & Mechanical
    Last Post: 07-15-2009, 07:42 PM
  4. E27 new 12v control panel
    By CWM in forum Maintenance & Mechanical
    Last Post: 04-16-2008, 05:18 AM
  5. Novatron control panel E-30+
    By lschill in forum For Sale & Wanted
    Last Post: 02-13-2007, 04:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
