Volvo Penta MD2030 Control Panel Replacement Parts?
bkuchinic
I'm having trouble locating replacement parts for my engine instrument panel. Would anyone be able to point me in the direct of a supplier for "plug and play": replacement instrument panel parts?
The gauges work (oil pressure, tach, temperature, voltmeter). I need all of the components that are clustered in the lower right of the panel, including the ignition switch (I only have one key), alarm buzzer and four warning lamps (oil pressure, charge, glow plug, engine coolant temperature), alarm test and instrument light switches.
View attachment Volvo Penta MD2030 Wiring Diagrams Instrument panei with ignition switch.pdf
EGregerson
volvo
Hi; check out volvopentastore.com. Click on Genuine Engine parts; Select your engine model; Select Electrical system. My ignition switch was part No 3587072.
bkuchinic
Thank you, that’s exactly what I was looking for! I have to figure out which Volvo Penta engine I have. It’s an MD2030 but I don’t know if it’s A, B, C, or D. Perhaps the print date of the manual will tell me... or a tag on the engine itself.
EGregerson
volvo
u can contact them at volvopenta.us via contact form; i imagine they can tell u which model it is based on the serial number; or contact iboats.com; they have a volvo penta portal; they sorted out the seals issue i had for the raw water pump.
