For Sale- 1975 Ericson 32-2 - Electric Drive - Newly Refit
Swanie
1975 Ericson 32-2
OAL- 31’6”
LWL- 24’
Beam- 9’9”
Draft- 4’11”
Disp- 8,800 (listed) 10,000 (actual)
Ballast- 4,000
Fresh water- 30 gals
Waste – 18 gals
This is one of the finest examples of any boat from this era. Painstakingly refitted (completed 2017) and repowered with a 10KW Electric Yacht and 48 volt system. Runs nearly silent and recharges from shore power or a portable generator. This boat sails like a dream and the electric power can be applied just enough to get you through the lighter wind areas of the bay. The motor will regenerate power when sailing. The list of new items includes:
  • Re-galvanized 24# Bruce Ancor with 30’ 5/16 chain and 300’ of nylon rope
  • Rebuilt manual windlass
  • Reinforced Bow to support the windlass and bow-roller
  • Pad eyes to secure a Honda eu2000i generator on the bow
  • New Ventas Ocean Hatches for the v-berth and main salon
  • Rebuilt companion way slide hatch and stack boards
  • Re-bedded all stations with g10 backing plates and through bolted
  • All new bulkheads- ¾” Marine Grade BS1088 Plywood
  • Rebuilt all chain plates
  • New running rigging
  • New standing rigging
  • New lower rudder bearing
  • Main sail inspected and repairs made- double reef and full batten
  • Fore sail furler cleaned and repaired
  • Mast stripped and painted with Interlux Perfection wiring conduit secured internally
  • New Mast head instruments (garmin) new antenna and conduit cable
  • Garmin GNX wind and vessel instruments NMEA 2000 network
  • Garmin 742 Chart Plotter NMEA 2000 network
  • Electric Yacht 10KW Electric Drive System- (regenerates when sailing)
  • Eight 6 volt 200 aH Life Line batteries
  • One 12 Volt House battery
  • 48v to 12v converter to charge house battery off of main pack
  • 48v Quick Charge main battery pack charger
  • New Blue Sea DC panel
  • New Blue Sea AC panel
  • Entire boat completely rewired with marine grade electric circuits
  • 120v 2.5 gallon water heater- operates on shore power or portable generator
  • New 18 gallon waste tank and all new “no smell” waste hoses
  • Fresh water tank cleaned and all new fresh water hoses and water pump.
  • New bilge pump and hoses
  • New manual Whale bilge pump in cockpit
  • Wheel Steering
  • All decks and cockpit core replaced and re-glassed
  • New anti-skid through all decks and cockpit
  • CPT auto-pilot
  • All decks, cockpit and topsides have been repainted with Interlux Perfection
  • Hull was barrier coated and new anti-fouling in April 2018
  • New salon and v-berth upholstery
  • New manual marine toilet
  • All new interior lighting
  • All new LED navigational lighting
  • New dodger with stainless steel tubing
  • New cockpit cover (weather protection when mooring)
  • 2017 professional survey performed- Valued at $30,000 before dodger, auto pilot and electronics. Replacement value at $131,000.
$22,000
Currently moored at Foss Harbor in Tacoma, WA and available for sea trials
silver sands
75 E32 for sale still ?
Hi Swanie, did you sell you electric 32? If not I'd love to see a few pictures.
Thanks Mike Walling
Vancouver
aka silver sands
