Results 1 to 9 of 9
Thread: Bilge pump wiring practices?
  1. #1
    Contributing Member I cagarren's Avatar
    Join Date
    Jun 2018
    Location
    Southern Oregon
    Posts
    17
    I'm rewiring our E 25 and am unsure of the standard practice of bilge pump wiring. Should its power come from downstream of the battery selector switch and this switch just always left on? Or wired directly to a battery? I can also see this dilemma as to wiring the little solar charger I just ordered.
    Curt
    E 25
  2. #2
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,775
    Blog Entries
    77
    I'm wired direct to the batteries.
    More than anyone really wants to know: http://www.ericsonyachts.org/infoexc...Considerations
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  3. #3
    Contributing Member III
    Join Date
    Apr 2017
    Location
    Boston - Maine
    Posts
    56
    One thing solar really helps with is battery discharge paranoia. I now leave my battery selector ON all the time, on battery 2 (always the older one) and have the dodger-top solar panel keeping that always topped off. I wired the solar charge controller to the switch instead of the batteries direct because I want to always be able to keep the two batts separate, and I don't have a 2-batt output solar charge controller (although that's in my thoughts).
    This Spring I plan on wiring the main bilge pump direct to the battery (2) through a water-witch switch like Christian used, so it just keeps the bilge mostly empty all the time and even if the switch or pump breaks and remains on all the time I just drain out my weaker battery which is the downside of battery wired bilge pumps. If batt 2 dies, I always have the fresh batt 1 to start the motor. The current panel bilge switch will be just for manual-on then. The front (shower drain) bilge has its own diaphragm pump and float switch and manual/auto switch which will stay that way.
    I really enjoy having the peace of mind the solar panel brings. Even if I leave cabin lights on (all LED now) the solar provides more electrons than all the lights can take over a day, so I always have a good charge when I get to the boat.
    fyi my son had the brilliant idea of routing the solar panel wires from the dodger down through one of the traveller end-boxes on the cabin top, then under the headliner, then down the metal hand-hold pipe on the nav-desk/saloon bulkhead and right into the battery box by dremelling out a slot in the back of the metal tube and drilling into the battery box there. Its such a clean install.
  4. #4
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,372
    Blog Entries
    62
    Electircal Wiring Notes
    I much prefer to have all major battery loads sourced from the main DC panel, where power can be controlled by our single rotary master switch. If you decide that you want to have a separate wiring run to the bilge pump, be SURE that you have it safely fused right at the battery.
    There is a small Blue Seas connection device that will do this, for several loads at a time.
    It looks full-up on our boat because several voltage sensor wires come to it along with the shore power charger input.
    Click image for larger version.
Name:	BlueSeas Batt Fuse terminal.jpg
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  5. #5
    Curator of Broken Parts toddster's Avatar
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,514
    Blog Entries
    48
    I keep changing my mind about this. Currently its wired to a main hot buss after the battery switch, and that switch is left to the main house bank on all the time. The reasoning being if the house bank died Id want the ability to switch critical loads, including the bilge pump, to the back-up battery. Topologically, I guess this is the same as wiring it to the house panel. Except as Loren mentioned, as long as that wire is in the main panel, one could re-configure it just by slipping the wire terminal off the load buss and onto one of the battery studs. Not all boats have a separate main panel, but I dont like extraneous wires on the battery posts.
    BTW: My bilge pump did blow a fuse last month. It turns out that the fuse that comes in the little Rule switch panel is actually too small for the Rule 2000 pump. Now Im thinking of replacing that with a circuit breaker, since it took a week to source a new fuse.
    s/v arcturus E29 #134
  6. #6
    Join Date
    Jun 2018
    Location
    Southern Oregon
    Posts
    17
    Good info as always. I will probably wire the pump control switch to the main bus and leave it on. As long as everything is fused correctly it should be ok.
    E 25
  7. #7
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    1,152
    Blog Entries
    23
    When I re-do mine (hopefully within the next few weeks), I'm doing "both"
    -- existing centrifugal pump will remain as it is, wired through the battery switch and plumbed from the forward bilge pocket where it sits on top of the keel-bolts
    -- new diaphragm pump will be wired directly to battery, with a fuse block on the battery post as Loren has done, and plumbed to the middle bilge-pocket with a water-witch switch as Christian has done.
    Partly because that means I can get the new system wired/plumbed/tested before decommissioning the old. But also partly because keeping the old one doesn't hurt anything, so (for the moment), why not.
    ObNote, that "should" mean that the centrifugal never activates because, if the new system works as expected, water will never get high enough to trigger the centrifugal's internal float-switch. We'll see. There's a "tee" fitting at the exit-thru-hull under the transom where the shower-sump plumbing used to connect, so I can easily run them both to that exit, but I do know that if there is ever a time that BOTH pumps are running, that single-exit will constrain the amount of dewatering that happens.
    Bruce
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  8. #8
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,775
    Blog Entries
    77
    So, what is left to "sink" me?
    Uh, forgetting to leave the bilge pump energized.
    Yeah, I'm wired direct to batteries, with fuse. But the wires go to a three-way switch --Manual, Auto, off.
    Occasionally I wake up (at my desk) with the thought: Say, did I leave it set to Auto?
  9. #9
    Contributing Partner kiwisailor's Avatar
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    123
    Blog Entries
    19
    Bilge Wiring
    I rewired by bilge pump wiring a year or so back during my panel rebuild. My bilge pump switch comes off the main DC selector 3 position switch: 2 (house), 1 (start), off. The benefit is that the bilge pump can be selected across to the start (G27) battery and when switched off all DC wiring is isolated and dead. One extra thing I did was install a small Blue Seas 12V green LED on the bilge switch itself that I can eyeball and see if the switch is in the auto position and is live, that is power is feeding to the bilge "water witch" switch. https://www.bluesea.com/products/817...2_24V_DC_Green
    The picture below shows the bilge switch at top left of panel with green LED on.
Name:	Bilge Switch.jpg
    I've also gone and installed a separately fed high bilge alarm using an Johnston Pump Ultima two wire electronic bilge switch. This activates both audible and visible alarms on the main DC panel as well as at the Navpod in the cockpit. In addition it latches a relay to run the bilge pump effectively bypassing the primary bilge switch. These circuits are all fused.
    The bottom line is though I always leave my DC panel switch in the 2 (house) position.
    Sherene & Mike Taniwha
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
Similar Threads
  1. 1976 32 Bilge - automatic bilge pump ideas
    By scourge in forum Maintenance & Mechanical
    Last Post: 12-08-2018, 06:54 PM
  2. E 28 Bilge and Shower pump wiring
    By Afrakes in forum Maintenance & Mechanical
    Last Post: 04-20-2014, 11:52 AM
  3. Electrical help with bilge pump wiring, please
    By Frank Langer in forum Maintenance & Mechanical
    Last Post: 06-28-2012, 04:41 PM
  4. wiring bilge switches when using ACR and 1/2/Both/Off Switch
    By davisr in forum Maintenance & Mechanical
    Last Post: 04-20-2012, 10:44 AM
  5. re-wiring and cleaning bilge on th E-35-2
    By Barr88 in forum Maintenance & Mechanical
    Last Post: 04-18-2012, 06:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
