Results 1 to 11 of 11
Thread: Ericson 32-3 Icebox Size for refrigeration
  1. #1
    Principal Partner GrandpaSteve's Avatar
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    386
    Trying to decide between the Isotherm 2501 or 2301 and I am not sure of the icebox size. I ripped out a rusted-out Alder Barbour unit 6 years ago and I am finally going to replace it.
    Of course any advice is appreciated. The PO was very happy with the original unit setup.
    1987 E32-III "Glory Days"
    Hull #711
    Slip in Rock Hall MD.
    Home in Downingtown PA.
  2. #2
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,430
    Blog Entries
    62
    Lightbulb
    Quote Originally Posted by GrandpaSteve View Post
    When I was preparing for our fridge install, I measured the inside of our ice box. Since it consists of a wider upper part and narrower rectangular lower part, I could diagram it as two 'boxes' and just add up the cubic inches of both for a total.
    Convert those to cubic feet (not very darned many cubic feet...) and you are ready for choosing the size evaporator that will do the job.
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  3. #3
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,832
    Blog Entries
    77
    I would put in the larger one if the evaporator will fit--price seems about the same.
    My old Dometic, very similar, runs continuously 12 months a year in the slip. I had previously been an ice man. By the gods, refrigeration is great!
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  4. #4
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    386
    Quote Originally Posted by Christian Williams View Post
    I’m sure the larger evaporator will fit, so I guess in this case there are no drawbacks in going bigger? Also, I did a week long cruise with a good friend last year on his Catalina 380 with refrigeration and it was great to not have one of the tasks in each port being “how’s the ice doing, where do we get ice?”. That left an impression on me.
    Hull #711
  5. #5
    Makes Up For It With Enthusiasm Geoff W.'s Avatar
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    279
    Blog Entries
    3
    My only complaint about my fridge in my 32-3 is that it freezes (and explodes) canned beverages within close proximity of the cooling plate. Not sure what's to be done about that, but perhaps a bigger fridge may exacerbate that issue.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  6. #6
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    386
    I ordered the Isotherm 2501. I will keep you all posted on installation and performance, thanks.
    Hull #711
  7. #7
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,832
    Blog Entries
    77
    Geoff,
    Same deal. Inside the evaporator ring things freeze, even on the lowest setting. Of course, that's good for ice trays.
    I am using a drop-bag idea based on small white cotton drawstring bags that may have once held women's shoes, or gifts or something. I put a half-dozen drinks in each--Diet Coke in one, water in another, beer in a third.
    They lower down into the refrigerator on a line. If you want a water, pull the water string up. This has relieved the irritation of bending over double to reach to the bottom of the fridge for a beverage you can't see. Sounds silly but it works. And I know easily when only one Coke's left.
  8. #8
    Contributing Member II
    Join Date
    Oct 2017
    Location
    Fox Island, Wa
    Posts
    33
    I use an external refrigeration system here in Gig Harbor —-Alaska? that requires little maintenance.
    Attached Images Attached Images
    Doug Wornell
    ”Island Bird”
    1985 E38 Hull#121
    Fox Island, Wa
  9. #9
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    1,187
    Blog Entries
    23
    Quote Originally Posted by llenrow View Post
    I use an external refrigeration system here in Gig Harbor.
    I have a similar system at work in Everett right now...
    Click image for larger version.
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  10. #10
    Principal Partner markvone's Avatar
    Join Date
    Aug 2007
    Location
    Bethesda, MD
    Posts
    640
    Some Insulation Ideas
    I have an Adler Barbour Super Cold Machine from the PO. It has large cold plate along the edge of the box that will freeze anything near it or anything on the bottom of the box, below the mid-level shelf, even though I run the unit on '1' out of '10'. My box has an extra one inch of insulation on the inside and I believe this reefer unit could run the whole box as a freezer on the higher settings. I added a one inch thick pink insulation barrier with a 3 inch hole in it to isolate the cold plate from the box. This keeps the lower box above freezing. A piece of insulation strategically placed can probably solve your freezing issues. You can get a 2x2 foot piece of this insulation from Home Depot.
    I've experimented with moving the barrier away from the cold plate to gain more "freezer" space for ice. You can see the blue ice cube tray below the cold plate and behind the pink barrier in the second picture. In the third picture, I removed the barrier and sealed the lower level of the box with a thin piece of removable plywood to make the lower section of the box a freezer.
    Mark
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	26111   Click image for larger version.
ID:	26112   Click image for larger version.
    Mark & Ronnie Vinette
    E36RH #21 GLIDE
    Annapolis, MD
  11. #11
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    386
    The reason I picked the Isotherm 2501 over the 2301 is because the E32-3 color sales brochure claims the icebox is 6 cubic feet. I won’t be visiting the boat for a few weeks and I wanted to order the refrigeration while it was on sale at Defender.
    Hull #711
Similar Threads
  1. Ericson 32-3 Refrigeration
    By GrandpaSteve in forum Design & Function
    Last Post: 04-15-2019, 06:31 AM
  2. Looking into adding Ericson 32-3 Refrigeration - additional questions
    By oldfauser in forum Maintenance & Mechanical
    Last Post: 06-10-2018, 08:17 PM
  3. Ericson 35-II genoa size
    By hinters in forum Design & Function
    Last Post: 11-04-2009, 07:41 PM
  4. prop size for Ericson 32-3
    By Chris VanHaaren in forum Design & Function
    Last Post: 10-11-2009, 04:55 PM
  5. Ericson 38-200 Refrigeration
    By oceandreams89 in forum Maintenance & Mechanical
    Last Post: 06-01-2004, 07:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
