If Delightful is not already set up for a spinnaker, an asym will be a MUCH shorter on-ramp.
To make a symmetrical work, you'd need
-- topping lift to hold the pole up (you could use a halyard, but it's not great)
-- foreguy to hold the pole down (generally through a block on the foredeck - you could put the block on the anchor roller but, again, it isn't optimal)
-- a way to put the pole on the mast (at minimum, a strong "eye", but a track with adjustable car is better)
-- a place to store the pole when not using it (chocks on the deck, or on the stanchions)
...plus sheets and afterguys, plus a plan for having sheets and afterguys on winches that maybe already have jibsheets on them as you go around a mark, plus, plus...
An asym needs a halyard, a tackline and a sheet. Much easier. And you don't have to drill any holes in the mast or the deck....
...you know, until you decide you want to get "serious" (lol)
Bruce
