Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: A minor modification that might be of interest...
  1. #1
    Join Date
    Apr 2006
    Location
    Nanaimo, British Columbia, Canada on Vancouver Island
    Posts
    1,863
    Hi,
    As most boats do, ours has a warning buzzer to alert us if the engine overheats or the oil pressure drops. It also sounds when I turn on the engine key before the engine starts and oil pressure rises enough. It also sounds if I turn the key to run the fuel pump to bleed the fuel line after a filter change. While I do want notice of a problem, I hate that noise!
    My solution was to cut the connecting positive wire and add a spade connector so I can easily unplug the buzzer when I don't want it to sound.
    My young grandkids are also much happier when they're on board as they don't have to cover their ears any more.
    As long as I remember to reconnect it after I unplug it, it should work perfectly!
  2. #2
    Principal Partner Afrakes's Avatar
    Join Date
    May 2009
    Location
    Port Kent , NY 0n Lake Champlain
    Posts
    529
    Toggle switch
    Why not a toggle switch?
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
  3. #3
    Join Date
    Apr 2006
    Location
    Posts
    1,863
    Yeah Al, that might have been even better! 😊
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,601
    Blog Entries
    77
    I'm worried.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  5. #5
    Join Date
    Oct 2015
    Location
    Georgian Bay, Ontario
    Posts
    136
    "I'm worried."
    agree.... necessary equipment there for a very good reason, should not be played with.
    As annoying as it might be.... just a few seconds
    1978 35-2
    Crystal Current
  6. #6
    Join Date
    Oct 2015
    Location
    Posts
    136
    not too much of a stretch to see how this very simple mod could cost someone a diesel engine
    1978 35-2
    Crystal Current
  7. #7
    Contributing Member II
    Join Date
    Jan 2014
    Location
    Cabrillo
    Posts
    28
    I added a delay-on-make relay to mine. Key ON, the alarm system does not arm for 10 seconds. No switch to remember to flip, no wire to remember to attach.
  8. #8
    Join Date
    Apr 2006
    Location
    Posts
    1,863
    Yeah, I could see that if a boat owner is careless, and for that owner this would not be a good modification.
    In my case where I'm usually alone when I replace filters and have to turn on the key in the cockpit to run the fuel pump, then climb down into the engine compartment to bleed the fuel line in two places before climbing up and back into the cockpit to turn off the key - - that's a long time to have an annoying buzzer sound for me and my boating neighbours.
    But it's a choice.... maybe not for everyone.
  9. #9
    Principal Partner Kenneth K's Avatar
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    327
    Blog Entries
    6
    I wrapped electrical tape around my buzzer until it was at a suitable noise level. Can still hear it over other noises but it's no longer painfully loud.
    Ken
    '85 E32-3 "Mariah" #641
    Universal M-25
    "Saltwater is the cure; sweat, tears, or the sea......"
  10. #10
    Join Date
    May 2009
    Location
    Posts
    529
    Gauges and eyes
    Not too long ago there were no warning buzzers just gauges and eyes. What do deaf sailors rely on? If your not paying attention things happen. Have a checklist, follow it and look at those wonderful gauges. That's what they're there for.
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
  11. #11
    Join Date
    Oct 2015
    Location
    Posts
    136
    yes to all of that, and milk used to be delivered by trucks with blocks of ice.
    Why intentionally circumvent a designed safety feature?
    1978 35-2
    Crystal Current
  12. #12
    Join Date
    Oct 2015
    Location
    Posts
    136
    also maybe get rid of those annoying high water bilge alarms and just check the water level regularly
    1978 35-2
    Crystal Current
  13. #13
    Join Date
    May 2009
    Location
    Posts
    529
    Helpful hints
    Don't get rid of all those wonderful aids. But also don't come to rely on them totally. Pay attention to the details. Good hoses, good clamps, good packing, check your coolant and lubrication level. Just don't wait until one of those little buzzers lets you know you've ignored something important.
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
  14. #14
    Join Date
    Oct 2015
    Location
    Posts
    136
    absolutely agree Al.
    They don't call them 'idiot lights' in autos for nothing ; )
    Nothing replaces care and attention.
    1978 35-2
    Crystal Current
  15. #15
    Join Date
    May 2009
    Location
    Posts
    529
    Back to the original point
    Frank: I assume that if you're smart enough to come up with a way to temporarily interrupt a buzzer you're also smart enough to reverse the process. My suggestion of installing a toggle switch I believe is a lot easier then manipulating spade connectors over and over. Remembering to turn a switch on/off and off/on is also practicing good "seamanship". I'm not worried.
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
Similar Threads
  1. New England/Long Island Ericson Regatta - any interest?
    By Mel Snyder in forum Ericsons Northeast
    Last Post: 07-15-2014, 02:47 PM
  2. Serpentine Belt Kit For M-25's - Any Interest?
    By Maine Sail in forum Maintenance & Mechanical
    Last Post: 02-04-2012, 01:02 AM
  3. E29 - help - minor c02 poisoning in v-birth
    By adam in forum Maintenance & Mechanical
    Last Post: 07-08-2011, 01:47 PM
  4. E 39 General interest and photos
    By stillwater in forum Cruising & Racing
    Last Post: 10-02-2008, 09:37 AM
  5. Splashed and some minor issues
    By treilley in forum Maintenance & Mechanical
    Last Post: 05-12-2007, 07:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
