Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 46
Thread: [E32-3] How do you remove the head hoses on an E32?
  1. #31
    Makes Up For It With Enthusiasm Sati's Avatar
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    Click image for larger version.
    The farthest forward bilge port I have is the one just aft of the mast, where the mast drains and shower sump empties. Sole is still glued down, don't think it's been removed yet.
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  2. #32
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,743
    Blog Entries
    77
    It looks like you have access to the main TAFG bilges. The forward two arenʻt connected with limber holes, however (theyʻre really just tab attachments to the hull) .
Name:	Theonious bilge C.jpg
ID:	26261Click image for larger version.
Name:	Thelonious forward bilges.jpg
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  3. #33
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    I imagine those forward pockets have some gnarly business going on right now. The sole is making a pretty significant squelching noise when I step on it. Is there anything I can do to try and speed up the drying process for this, space heater, dehumidifier? Patience?
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  4. #34
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,743
    Blog Entries
    77
    Won't hurt to try.
    But if the plywood has actually absorbed water---well, everything has a lifespan.
    We had a recent thread in which an owner removed a glued-down sole without destroying it. Maybe somebody can remember it.
    Once removed, sometimes you can save a portion of sole with CPES and epoxy and beat the tedious full replacement job.
    But let me not think up things to do--if it'll dry out, good enough.
    Now that I think of it, it is common for bilge access hatches to have finger holes in them for lifting. If trapped water is suspected, you could always drill a finger hole over the compartment and pump water out through that. And just consider the remaining hole a "finger hole."
  5. #35
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    The wood isn't squishing by the end of today, so it must be drying, but its still sitting a bit proud of the surrounding cabin liner. Maybe it always was, I dunno. Will probably look at the sole rehab later this year assuming nothing else catastrophic happens. No head smell is stuck lingering either, so that's good.
    Tin Kickers eval of composting heads fitting in the 32-3 made me pull my holding tank out of the bin and I spent a large part of today re-running hoses. I'm using White Trident 102 hose...$11 a foot at Fisheries Supply here in Seattle. Jeez. also replaced the two bottom fittings on the holding tank with new PVC fittings and installed a new PHII hand pump. I have most hoses back in, but the run from the Whale Gusher to the holding tank defeated me after 2 hours tonight. Stupid S curve....
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  6. #36
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    Finished the job yesterday. Thought I finished on Sunday, but it turned out the Y valve was dripping, as well as one of the plastic hose fittings that screws into the "overboard" thru-hull. I replaced the old Jabsco Y-valve with a new Jabsco Y-valve. I know they get something of a bad rap in the threads I've seen, but seeing as I had already cut and run the hoses to fit one, I replaced like with like. Pretty easy job to replace, too - compared to the others. As for the plastic fittings, I pulled them from the thru-hulls themselves and re-taped the threads with teflon tape. Seems to be holding for now....
    The new PHII pump pulls water into the head and pushes it out with gusto. I don't regret replacing entirely instead of just rebuilding.
    I ended up using Trident 102 hose for the whole system, except for the raw water intake and sink drain. That was some sort of basic Max-flex cheaper hose, but I'm less concerned because those don't hold "troubled waters." Chances are, if/when some aspect of the system fails in the future, it won't be the hoses permeating.
    Note: I went with 25 feet of 102 hose and that was just barely enough with maybe 2-3 feet of wastage. I used 2 feet of 1" Maxflex for the sink and maybe 2-2.5ft of 3/4" maxflex for raw water intake. I also used 6-7 feet of 1/2" clear water hose for the air vent to the holding tank.
    Everything is much cleaner - there's still sort of a dank smell if the head door has been closed for a while, but I think that might be the residual dampness and old grossness under the sink cabinet. I cleaned that out a lot with bleach and paper towels, but it might require some additional attention. I'm also going to try putting a small passive dehumidifier down there to see if drying the whole area out helps -- who knows how long that Y-valve and other fittings were slowly drip drip dripping down there.
    I had a mild heart attack last night when my brain convinced me I had plumbed the deck fitting to the top of the holding tank instead of the bottom. After pulling the whole v-berth apart again, and triple-checking, I did it right the first time.
    All in all, it feels really good to have completed my first "big" project on the boat - one I have plenty of bumps and bruises to show for. It also has given me some confidence that no matter how screwed up a job gets in the moment, everything on the boat is ultimately a physical object that can be repaired, rehabilitated, or replaced. Thanks all for the advice/etc.
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  7. #37
    Contributing Member III
    Join Date
    Jan 2019
    Location
    Annapolis area
    Posts
    41
    Congrats on achieving that good feeling!
  8. #38
    Join Date
    Jul 2011
    Location
    Knoxville TN
    Posts
    125
    Quote Originally Posted by Sati View Post
    I think you will be able to suck the gnarly fluid out of the bilge pocket that's slightly forward of the mast (one of the ones under the squelchy flooring, with no access panel in the floor) ...
    ... go into the storage space under the seat that's on the port side of the mast. In the forward right corner you may find a small hole (I can't recall if you first have to undo a small access plate in the bottom of that locker?). Poke a hose down there and suck out the trapped liquid. It's about 15" from the hole in the settee locker to the middle of that cavity. When it's really full, you'll be able to get about a pint of water out of it. When I eventually redo my flooring, I'll include access panels for that bilge in the floor, AND, I plan to use latches to secure the floor panels so they can all be lifted up as and when needed.
    Since Christian has pulled up all the flooring, maybe he knows where that liquid comes from, and where it (slowly) drains to.
    E32-3 #655
    Traveller
    Knoxville, TN
  9. #39
    Principal Partner Kenneth K's Avatar
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    378
    Blog Entries
    6
    I had some loose sections of cabin sole that would also "squish" when I pressed on them when wet. Rather than delamination of the sole, the squishing was coming from areas where the plywood had come unglued from the TAFG. And, yes, these areas where sitting up proud of the rest of the sole.
    If you can get a putty knife or a finger up under the raised edges of the sole, you might be able to wedge small pieces of cloth underneath to absorb more water. Or, keep them pry-ed upward and use a fan to help dry underneath.
    If you can pull up on the loose sections just a bit but then feel a lot of resistance, your plywood and veneer are probably intact like mine were. I can't imagine rotting or delaminated wood would be so firm.
    If you do have loose (unglued) sections of sole, they'll be your best friend when you go to remove the sole. I was able to remove my aft section of sole intact just a few weeks ago. Pictures posted near the end of this post: http://www.ericsonyachts.org/infoexc...bin-sole/page6
    Ken
    '85 E32-3 "Mariah" #641
    Universal M-25
    "Saltwater is the cure; sweat, tears, or the sea......"
  10. #40
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,743
    Blog Entries
    77
    E32-3 foreward bilges
    In the photos, "3" is the same bilge.
    As I recall, there is a crude opening in the molded side of the head shower sump, put there by the factory.
    That can be used to pump out water trapped under the TAFG in that area.
    The keel bolt bilge #3--does that have a limber hole to anywhere? I don't think so. My photos are ambiguous.
    Note the two small drill holes at mast base. They direct mast rainwater directly under the TAFG, where some of it gets trapped.
    Some previous owner thought that was better than pouring out over the floorboards. I didn;t disagree.
Name:	Thelonious forward bilges - Copy.jpg
ID:	26364Click image for larger version.
Name:	thelonious mast bilgeIMG_2852 - Copy.jpg
  11. #41
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    Quote Originally Posted by Christian Williams View Post
    As far as I can tell, there is no limber hole in bilge pocket #3. I see a hole in bilge pocket #2, which I believe is the pocket nquigly is referencing as being accessible from the port settee storage.
    My bilge pocket #3 has a strangely glassed hole cut into the forward-port corner, leading to....the TAFG? Kind of unsure. This might be a manually added drain for Bilge Pocket #2, now that I think about it.
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  12. #42
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,743
    Blog Entries
    77
    That may or not be a hole in Bilge #2. I don't recall, but I doubt it. Too near the hull and too small diameter.
    However, adding drain holes on the vertical sides of the TAFG isn't a bad idea.
    The factory did it on some boats, and it's an easy way to rid the hidden recesses of water.
Name:	1-TAGF drain 1.JPG
  13. #43
    Join Date
    Jul 2011
    Location
    Knoxville TN
    Posts
    125
    As far as I can tell, there is no limber hole in bilge pocket #3. I see a hole in bilge pocket #2, which I believe is the pocket nquigley is referencing as being accessible from the port settee storage.
    The bilge I was accessing via the settee locker was the #3 bilge in Christian's latest post - it has the forward-most keel bolt in there - you can feel it with the hose I mentioned.
    It's a total mystery to me why they glued floor panel pieces over a bilge that contained a keel bolt without making an access panel in the floor. Oh well.
    E32-3 #655
    Traveller
    Knoxville, TN
  14. #44
    Join Date
    Jul 2018
    Location
    Seattle, WA
    Posts
    226
    Blog Entries
    2
    Quote Originally Posted by nquigley View Post
    Oh well.
    I actually think I do have an access panel for that bilge...it's the one my mast drains into, unless I'm super confused. I guess it must have been added by the very first PO, if that's not factory standard.
    If there were two bilge pockets containing funky gunk on my boat, they'd be the two forward of the mast - these are inaccessible with the sole in place.
    I should mention Ken's post makes me feel a lot better about the once-squishy sole (thanks Ken). The wood itself feels solid, it must just be unglued. Still a project worth doing this year sometime.
    Geoff W.
    s/v "Delightful"
    1987 E32-3
    Hull #712
  15. #45
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    378
    Blog Entries
    6
    Just to clarify, for me, if not for someone else: I think the forward-most keel bolt on the 32-3 is under that little hole forward of the mast step.
    The second keel bolt would be the one shown in "bilge number 3" from earlier posts (where the "shower" bilge pump is normally installed and where rainwater from the mast collects)--which is not visible in this photo, but normally has a bilge access cover over it to provide access to the "shower" bilge pump.
    Ken
    Universal M-25
Similar Threads
  1. Replacing Head intake/outake hoses - E26
    By BDEidson in forum Maintenance & Mechanical
    Last Post: 10-12-2011, 01:21 PM
  2. Ever remove the head from a Universal 5432?
    By rwthomas1 in forum Maintenance & Mechanical
    Last Post: 05-19-2010, 07:14 PM
  3. Head Hoses Replacement
    By saildog in forum Maintenance & Mechanical
    Last Post: 05-22-2006, 01:43 PM
  4. Replacing head and hoses
    By Lawdog in forum Design & Function
    Last Post: 12-05-2005, 06:38 PM
  5. Re doing the hoses and head
    By Luffin it in forum Ericsons Northwest & British Columbia
    Last Post: 11-01-2003, 09:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
