Farlander
Well I probably should have done this before I bought the boat. But I got excited. And here I am, so I'm going to make the best of it. My plans for restoration depend on the condition of the boat as well whether the sails turn out be correct.
First look at the bilge. When I bought, there was a one piece molded in carpet across the entire cabin sole, so I conspired against myself to use that as an excuse not to look. I suspected the bilge had water, but not a pair of eyeglasses, a box of emergency boat repair?, a freshly lost lazarette hatch, and submerged wires laying around. The rest of the inspection revealed some real shockers...
All photos here
The through hull for the bilge pump out is about to disintegrate. A throttle or primer pump? cable was broken and had been replaced by a piece of copper wire with a strand running through it. I'm enthralled...
The head seems to have just broken. It used to pump and flush and all that good stuff but now it is hard to lift the handle and the seal at the handle base leaks. Maybe I'm missing something, but no water passed through the bowl, in either flush or dry mode.
A smattering of broken wires. Mast top light (correct term?) does not work. Running lights light on the bow only.
The companionway sliding hatch is in about 3 pieces now. That will be a priority project to be able to forego the use of the tarp I am using now....
Not shown here is a very badly rusted engine mount frame, with particularly bad rust on the forward starboard engine mount support.
I saw some of the chainplates, they appear to be in good condition, no significant apparent rotting, no major delamination. The stainless steel caps on the bottoms of the hand rail screws are rusting, and I'm debating if that is from condensation, or leakage. Resealing those looks like a huge project which might receive caulk for christmas.
Advice on the head and companionway hatch would be most welcome. Head is a Raritan. I'm also hoping to change the oil before moving here, but I don't think the boat has the original oil sump pump, is there a good inexpensive unit I could pick up at a harbor freight or at a local marine store?
Gracis,
All photos here
Gracis,
