Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: "Pro" Tips
  1. #1
    Principal Partner bigd14's Avatar
    Join Date
    Sep 2008
    Location
    Portland, Oregon
    Posts
    551
    Blog Entries
    8
    "Pro" Tips
    I should have done this a long time ago, but I have been thinking about trying to collect all the little tricks and shortcuts that everyone develops for various boat maintenance activities in one place so that all may benefit. So what do you have?
    Here is the first one I have to contribute
    Affixing ring terminals to terminal strips
    Problem- Fat fingers and stiff wires lead to lost terminal bolts in the bilge
    Solution- Use a drill bit driver to hold and tighten bolts
    Click image for larger version.
    1984 Ericson 30+
    Hull #651
    Formerly 1972 Ericson 27
  2. #2
    Join Date
    Sep 2008
    Location
    Portland, Oregon
    Posts
    551
    Blog Entries
    8
    Working with G10
    Problem: Cutting and sanding G10 ruins tools and creates clouds of toxic dust
    Solution: Cut g10 with a jigsaw using a diamond abrasive blade. Minimal dust and clean cuts.
    For sanding and shaping the sharp edges place several strips of 80 grit longboard sandpaper on a flat surface. Work the piece over the sandpaper to smooth sharp edges and achieve final shape. Works also to rough up flat surfaces for epoxying into place. Takes a few seconds and no clouds of dust from electric sander.
    1984 Ericson 30+
    Hull #651
  3. #3
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,472
    Blog Entries
    77
    On #1, right on. Furthermore...
    Older boats have slotted screws on the panel; if so, change them all to Phillips, with spares. Phillips-heads stick on a driver much better. They will only stick if the driver matches--and for $6 we should all have a selection of driver bits.
    Also, use spade connectors on wires. I know, I know, ring connectors are "best" and "recommended." But spades slip on and off terminal posts, where three wires may reside and rings will drive you nuts. And spades are plenty secure.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  4. #4
    Join Date
    Apr 2006
    Location
    Nanaimo, British Columbia, Canada on Vancouver Island
    Posts
    1,805
    Put a dab of grease or Vaseline on a screw head to help it stick to the screwdriver and avoid falling into the bilge. Even more secure, push the screw through a piece of masking tape, bring the tape up to stick on the screwdriver, rip off the tape once the screw is in place, before final tightening. All this works with bolts too!!
    If you don't want to drill a hole too deep, wrap a piece of tape around the drill bit at the depth you want to drill, and stop drilling when you reach that depth.
    If your oil filter wrench is slipping on the filter, wrap a piece of sandpaper around the filter and try again.
    If clear or semi-gloss Varnish is too shiny and satin is too dull, a mix of semi - gloss and satin may be just fine, but stir regularly to keep the mix consistent across the whole area. This has worked well on my cabin sole.
  5. #5
    Sustaining Partner Kenneth K's Avatar
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    290
    Blog Entries
    6
    Tip for installing impeller ring-clip
    Most of us have decided by now that the ring-clip that goes on the shaft in front of the impeller isn't really required. It seems to work fine without it. However, if something about your personality just demands that the clip be there, here's the trick I learned.
    After the impeller is installed, pull it out slightly, maybe a quarter inch at most. The shaft will pull out along with it. Don't go too far, or as we know, the shaft disengages at the spline.
    Now you can insert a long flat-blade screwdriver into one of the cavities near the back of the pump. This will hold the shaft and place as you push the impeller deeper onto the shaft--deep enough to install the ring clip. After the ring-clip is on, push the impeller shaft back in as far as it will go.
    I also thought about using a long brass wood screw rather than a metal screwdriver to hold the shaft in place.Click image for larger version.
ID:	25086 Maybe less chance of scoring the wall of the shaft.
    If you must.....
    Ken
    '85 E32-3 "Mariah" #641
    Universal M-25
    "Saltwater is the cure; sweat, tears, or the sea......"
  6. #6
    Innocent Bystander tenders's Avatar
    Join Date
    Jun 2006
    Location
    Harlem Yacht Club, City Island, NY
    Posts
    1,051
    I’ve found that carbide blades work fine on G10 in my table saw and small battery-powered hand saw. As for dust...yeah, I wear a mask for that.
    My “pro tip” is to throw away those crimp butt connectors, both the cheap ones and the expensive ones, along with the crimper, in favor of Posi-Lock Connectors. They’re quite a bit more expensive, but they’re reusable. I bought a bunch of them quite reasonably in red, blue, and yellow flavors on eBay - they are fabulous for all electrical connections, including stereo/speaker connections, that aren’t sitting in water, where there is really no substitute for solder and shrinktube.
    This isn’t where mine came from, but it’s clear what they do:
    https://www.radiantz.com/Posi-Lock-p/223.htm
    1969 Ericson 32 #112 • Atomic Four
    City Island, NYC
    “Muxie Duxer”
    Hair by Mr. Gigi
  7. #7
    Join Date
    Jun 2009
    Location
    Long Beach, CA
    Posts
    158
    My favorite new connector
    I have only used a dozen of these so far so I can't speak for longevity, but, these are slicker than sliced bread:
    https://www.youtube.com/watch?v=7Wh5gM8GM70
    I only posted the Summit video for reference. You can find them from various suppliers on Amazon. Google "solder seal wire connectors".
    Other pro tip: hang your ignition key on your raw water through hull handle, you will never forget to open or close it.
    Matt
    1984 E35-III
    Former Partner S/V "Wind Chaser" #187
    Long Beach, California
  8. #8
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    996
    Blog Entries
    23
    definitely no "pro", but... I put a switch in the circuit between the engine panel and the electric fuel pump and mounted it down below near the pump.
Name:	fuel switch.jpg
    Now when bleeding the fuel system, I can energize the circuit at the switch on deck, but turn the fuel-pump off and on close to where I'm working when opening bleed-valves. Minimizes the amount of contortions and mess.
    Haven't tested this yet but, as a bonus, I can put the fuel system into an "anti-theft" mode. My boat doesn't have a key at the panel, just a switch, so anyone could climb onboard and motor away. In theory, I could turn off this switch - which is neatly hidden by the engine-compartment panel in the v-berth - and make it so a boat thief couldn't get very far.
    In theory.
    Bruce
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  9. #9
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,188
    Blog Entries
    57
    Question To lift pump or not to lift, that is the question
    Quote Originally Posted by bgary View Post
    In theory.
    Bruce
    Hi Bruce,
    One bit of Universal diesel trivia is that our former 3 cylinder engine used to run -sometimes- without the Facit electric lift pump energized, and sometimes it would also start without the electric pump (warm weather).
    In 2017 I had that pump wired separately with its own toggle switch to bypass the old high-resistance wiring in the harness and then sometimes would forget to turn on the switch.
    I did notice that the engine would mysteriously stop running sometimes when the electric pump was not energized.
    Diesels are simple engines, but there are odd little subtleties in their behavior.
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  10. #10
    Join Date
    Apr 2014
    Location
    San Francisco
    Posts
    100
    Extra long soft shackle
    Make up some extra long dyneema soft shackles (from the instructions on animatedknots.com).
    These can be used with 2 inch steel rings to make dog-bones for reefing the main. The advantage is that the open shackle can be slipped through a cringle on the luff of the sail, the rings attached, then the shackle closed, all without having to sew anything in place.
    Here's picture of another use of a long soft-shackle with a furler cam-block idea stolen from Loren Beach
ID:	25129Click image for larger version.
    Mike Field
    "Jenny" E35-3 #251
    San Francisco
  11. #11
    Curator of Broken Parts toddster's Avatar
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,398
    Blog Entries
    46
    Quote Originally Posted by MMLOGAN View Post
    Just about an instant sale here. I hate, hate, hate crimp-on butt connectors, which seem to have an extremely high failure rate for me. I note that several Amazon reviewers say they can't get the solder to melt before the heat shrink chars. The video suggests that some special heat gun or adapter is needed. What did you use and how well did it work?
    s/v arcturus E29 #134
  12. #12
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,398
    Blog Entries
    46
    Quote Originally Posted by Loren Beach View Post
    Hi Bruce,
    The injector pump does create a little suction - often enough to draw fuel with moderate throttle, but not enough to keep it running at idle or low speed. That's one of the symptoms that you need a new lift pump!
  13. #13
    Join Date
    Dec 2000
    Location
    Posts
    7,188
    Blog Entries
    57
    Quote Originally Posted by mfield View Post
    Not "borrowed" from me, but clever all the same. Those soft shackles are starting to appear on some boats around our little YC.
    (There have been so many great ideas presented on this site since Sean rolled it out many years ago that we could almost make a book of them!)
    1988 Olson 34 #8
    Sail # 28400
    Fresh Air
    Portland, OR USA
  14. #14
    Works great for jib sheets. Almost eliminates catching on the rig during tacks
  15. #15
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,472
    Blog Entries
    77
    Right. There is no reason to twist the cringle of a stiff mainsail over a reefing horn when a dog bone can be made up in five minutes. Use spare shackles and scrap of line to get the dog bone length right before making up the permanent version.
    Better yet (sort of) are reef cringle downhauls, led back to the reefing line brakes on the cabin house. Allows reefing, or shaking out a reef, without ever leaving the cockpit. I was skeptical (more gear, more lines) but now am sold.
Similar Threads
  1. Replies: 0
    Last Post: 02-22-2017, 11:30 AM
  2. Back issues of "Sail" and "Sailing World" - free for the taking
    By bgary in forum Ericsons Northwest & British Columbia
    Last Post: 02-21-2017, 09:08 PM
  3. "Sailing" or "Horsing" on a Buoyed Mooring
    By Kenneth K in forum Design & Function
    Last Post: 12-17-2016, 12:24 AM
  4. Original E29 skid "grid" repair/painting. Need tips.
    By adam in forum Maintenance & Mechanical
    Last Post: 01-16-2015, 05:04 PM
  5. "Choat" or "Chote" or ?
    By Sven in forum Maintenance & Mechanical
    Last Post: 03-24-2011, 01:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
