Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Hard to reach places - there's a thousand of them onboard
  1. #1
    Principal Partner footrope's Avatar
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    Anyone ever use this Flex Seal stuff around the boat or around the house? I might try it on the floor of the little plastic storage space there in the cockpit. I've used duct tape which gets old fast, and epoxy doesn't stick much. I'm not going to take it out anytime soon to rebuild it or repair it. It's in a painful spot to work on. Just wondering if it is any good at all. Maybe it melts plastic? As seen on TV!
    Click image for larger version.
Name:	20180701_Storage space-small.jpg
    Craig Davis & Ellen Le Vita
    1980 E38 "Pilot Project"
    Hull #20, Universal Diesel 5432
    Gig Harbor, WA
    In Puget Sound there are only two directions to go - North and South. That applies to the boat and the wind.
  2. #2
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    4,129
    Blog Entries
    78
    Plastic cubby insert gets destroyed by UV.
    I covered the underside with fiberglass and resin, then cut a plastic mesh dinner-table placemat to fit.
Name:	1-Ericson 32-3 coaming pocket trim.JPG
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  3. #3
    Curator of Broken Parts toddster's Avatar
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,653
    Blog Entries
    53
    No, but I think I've used similar products - though not in the form of a spray. Sealed up some seams and gutters on a metal roof about 15 years ago. So far so good. I did recently buy the companion product, "flex tape" for the boat's repair kit. It appears to be identical to the waterproofing membrane that I used on the foundation of my house. Peel and stick. Except the roll was four feet wide instead of four inches. I wish I had saved the butt-end of that roll. It would have been the equivalent of a fortune in "flex tape." And just what Robert Redford needed...
    It does get tacky in the sun. (The house stuff had a cellophane-like film over the non-sticky side to contain the tacky, but it wears away over time.)
    s/v arcturus E29 #134
  4. #4
    Principal Partner
    Join Date
    Mar 2006
    Location
    Winters, Boca Raton, Florida, Summers Glenview(Chicago) Illinois.
    Posts
    321
    Coaming Storage Box
    Craig: Do a google search on SSI Custom Plastics.....I got one of thier boxes 10 years ago and installed it.....was much easier than trying to repair the Ericson appriciation(sp?). I think I got it from Defender!
    Has held up beautifully...one of my better decisions...
    Good Luck
    Mort Fligelman
    A Capella
    E35-3 1987
    Glenview, IL
  5. #5
    Join Date
    Apr 2017
    Location
    Boston - Maine
    Posts
    122
    Was thinking of tackling that box this Summer as something that could be worked on while motoring about. Is the box that fits there just "flat"? It seems the coaming is a bit curved perhaps? Does the teak trim screws hold the box in or is it glued to the boat? Seems it would be easy to build/buy a box of the appropriate size with a flange that the screws bite into?
  6. #6
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    Based on the comments the Flex Seal needs to be tried somewhere else to see if it stays sticky/tacky. If it doesn't dry or if it softens in the heat, it might not be a good pick unless it is covered with some nice mat material, as Christian did. A very 80s decor choice. To get cloth/resin to stick I'd have to spend some time really sanding that floor in there. UV protection for the bottom is probably a very good idea, even up here in the sunny Northwest.
    I will check out SSI Custom Plastics, thanks. I would still have to dive in there and somehow get the box out, something I've started to do twice before and gave up. I've spent too much time working on other things in that lazarette to look forward to chopping it out of there.
    The teak trim ring screws on. The box is sloped down towards the opening where there are drain holes for the water that might get inside. The box is glassed to the boat as I recall, which is what stopped me before.
    Anyway, the can isn't going to be a fix without knowing more about how it comes out and how it cures.
    Thanks!
    Gig Harbor, WA
  7. #7
    Principal Partner
    Join Date
    Mar 2006
    Location
    Posts
    321
    More Coaming Box
    Craig: IIRC the box was glassed in, and it was a matter of hammer and chisel, and messy getting it out.
    The flange of the SSI box fits over the old holes, and I drilled the ones needed for the new box. I put the box up against the coaming and outlined it in pencil......blue taped it off and flooded the surface with caulk (sikaflex to the old 3M 100...can't remember which....but today would be butyl tape).
    Nothing is ever easy on these old boats.....but another headache out of the way is sometimes really worth the effort....
    BTW....the new box does not have a drain....but I do not don't find that a problem....it is easy enough to hose out if it gets dirty, and a quick swipe with a sponge empties it.....
    FWIW
    Best
    Mort Fligelman
    A Capella
    E35-3 1987
    Glenview, IL
  8. #8
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    Thanks, Mort!
    Gig Harbor, WA
  9. #9
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    I ended up using Flex Seal Tape to try to seal the storage compartment. I cleaned all the old epoxy and duct tape from the inside of the plastic box. I think it is made of some kind of resin, but without any cloth for strength. I aligned the cracked pieces of the bottom to help make the floor one level. Inside the lazarette I put a 20 inch length of 4 inch wide Flex Seal Tape on the outside of the bottom and wrapped it an inch or so up the ends. The 4 inch width is perfect for the depth of the box.
    The plastic box is so cracked, even the top surface is compromised. I wrapped a 6 inch piece around the aft lower corner where there is a significant crack at the radius. To strengthen the floor, now that it is held together with the tape, I may use 4200 to put a new floor inside, maybe out of 1/4 inch Starboard.
    The tape's sealing side is very sticky and hard to reposition as you apply it. It reminds me of black butyl sealing material, but the sticky stuff doesn't shed itself onto your fingers. That's nice. It has a thin plastic cover to protect the sealing surface while you test fit and cut it to the proper shape. It is non-stick on the back side which makes it easier to smooth out and move the bubbles around. We'll see how it goes, but I like the tape for now. We'll see how long it lasts after it "cures," which can take 24 hours.
    Gig Harbor, WA
  10. #10
    Principal Partner Kenneth K's Avatar
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    490
    Blog Entries
    8
    Be sure to post your results.
    My coaming storage box is intact but still leaks badly. The drain holes are slightly higher than the seam where the box is glassed into the boat. Water has managed to separate the layers of FG cloth and drains from the box into the boat. I hung a plastic cup from wire to catch the leaking water.
    My thought was to fill the leaking seam with "flowable" automotive windshield silicone to see if that will fill the seam.
    Interested to hear how the FlexSeal works.
    Ken
    '85 E32-3 "Mariah" #641
    Universal M-25
    "Saltwater is the cure; sweat, tears, or the sea......"
  11. #11
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    Quote Originally Posted by Kenneth K View Post
    I will post my results when I apply a water hose. I don't think Flex Seal tape would help with what you describe, if yours looks anything like mine under there. If your box has broken loose you might consider 3M 4200 or similar polyurethane sealers. Silicone residue will likely interfere with future repairs using epoxy or polyester resin. That is if you ever have to actually remove the box, or try to reattach it. Although it is an area you can sand enough to get rid of the residue, it does make it a little harder to prepare.
    If you clean out that gap reasonably well, and find a way to get the 4200 in there below the drain holes, it doesn't need a perfectly clean surface to seal up. You can also pack it and sculpt it with your fingers or small tools to make sure you cover the gap. Inspection mirror needed!
    Gig Harbor, WA
  12. #12
    Join Date
    Mar 2016
    Location
    Gig Harbor, Wa
    Posts
    490
    Blog Entries
    8
    I think I have the access to work 4200 in that corner, I'm just skeptical that anything will stick to that slick plastic that the box is made out of.
    Ken
    Universal M-25
  13. #13
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    You might try 4000UV, which is better on plastics. But if the box is made of polyester resin, either 4200 or 4000UV will bond to a reasonably clean surface. It's pretty sticky stuff. Here are pictures of the box after the Flex Tape was applied. Note the cracks. The plastic is very brittle and scraping it causes it to shed granules. I plan to sand it gently and then I'll fit a 1/4" piece of starboard inside, bedded/glued in with 4000UV (which is about $5 per tube cheaper than 4200).
ID:	27031 Click image for larger version.
    Gig Harbor, WA
  14. #14
    Contributing Member III
    Join Date
    Sep 2008
    Location
    Oriental, NC
    Posts
    64
    Blog Entries
    1
    I used resin and fiberglass cloth, sanded and coated with two-part paint.....has lasted a long time.
    Will admit using the Flex spray on our black concrete pool. It has stopped leaks and has stayed strong.
    Hilco on Sketcher
  15. #15
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,303
    Blog Entries
    11
    Quote Originally Posted by hilco woudstra View Post
    Hilco on Sketcher
    Finally, a Flex Seal testimonial! Thanks.
    After yesterday's rain, there is a leak at the aft corner. I think that is where there are cracks that are not covered by the tape. The cracks are almost against the coaming. Now I notice the gray/black stain on the underside picture. So, I'll try sealing from above with 4000UV, since I have an open tube. I will hold off on putting in the new floor for now as it will be easier to get sealer into the proper place so close to the inboard part.
    Gig Harbor, WA
Similar Threads
  1. Onboard sailing refresher on an E32
    By mikenberger in forum Cruising & Racing
    Last Post: 04-20-2016, 09:45 AM
  2. Onboard My Ericson
    By Rick R. in forum Lifestyle & Living
    Last Post: 02-28-2015, 04:04 PM
  3. E39 Close Reach 8.1 kts
    By gadangit in forum Cruising & Racing
    Last Post: 01-16-2014, 10:58 AM
  4. Onboard Navigation with Macintosh vs. PC
    By footrope in forum Cruising & Racing
    Last Post: 12-03-2007, 09:21 AM
  5. Places to go.
    By Guy Stevens in forum Ericsons Northern California
    Last Post: 10-13-2006, 01:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
