steven
Have installed and adjusted new carb (with fantastic and amazingly patient coaching/encouragement from David (Emerald) - thanks, David).
Running smooth.
However, the throttle arm cable connection on the carb is above the pivot.
No option to connect below the pivot as in the old carb (which had both connection options).
So at the helm, to add gas, you pull back on the throttle lever.
Formerly, push forward, which is more intuitive I think.
Not really a big deal, but does anyone know of a fix.
An adapter or something on the carb lever arm to connect below the pivot ?
--Steve
Running smooth.
--Steve
