The front cover plate is badly worn, folks seem to think faster it goes it might be pulling air and form a air gap.
The Jobsco will not work as I need the Male fitting to go into drive shaft. Every thing poi ts to the raw water side. When the thermostat opens around 165 up goes the temp. To over 210 and pegged. I only have 1600 NM to go but would like to have an engine.
What model pumps do other M40 universal engines gave cannot find that online. Stamped on pump side is 6595? Does any one have a cross referance? Thanks for any help
The front cover plate wear is a strong suspect in the pump not working. If water is coming out the exhaust when cool, but then stops after a bit, it could be the pump cover (happened to me a bunch of times).
When the pump stops working, stop the engine, take the cover plate off and pack the impeller with K-Y jelly and squirt some up the intake side if possible. Replace the cover, and then start the engine. If you get water back running then I'd strongly suspect the pump cover. (you can use vaseline too, but I would worry about where that would end up in the heat exchanger, etc.)
I've heard that you can carefully resurface the cover plate with sandpaper on a very flat surface, using finer grit till she's shiny. My solution was getting a new oberdorfer. If you're in a pinch, like it seems, I can't picture any downside to flattening the surface if you can. Just go slow and start with 200 or finer wet paper I'd think.
Call Scott Hutto at Pumps & Parts online 800-536-7867. I bought my new one there at a price lower than what I saw used "refurbished" ones for elsewhere. He'll be able to tell what pump you need based on engine info, pics, etc.
Good Luck!
Oh, PS, one thing I thought of (the day after my last near-overheat) is that I could have used my water-heater tank system as an emergency cooling system. The engine coolant runs through the hot water tank and if I ran my hot water it would pump cool fresh water into the tank cooling the engine. If I could extend my shower head a bit I could get it to reach the stbd tank inspection port and use the tank and shower plumbing has a heat sink. I think that, and taking off the engine cover could almost allow continuous use of the engine at slow cruise. I plan on keeping my fresh water hose onboard all the time and getting a fitting for the sink faucet maybe... but the new pump is so reliable that had slipped my mind.
