1967 ericson 30 propeller question
meemee
Hi I have an ericson 30 with a yanmar sb 12 My present prop is 12 x 12 two blade.
The boat weighs 7800#
I motor alot on the Hudson river which being as estuary has two tides per day
The current is 2 mph
in the current the boat does 5 knots and when current is minuimum it does 6 knots
I have 4 inches from the tip of the prop to the hull.
I need more power in the current and wanted recommendations for a new prop. 2 blade ? three would be fixed as my budget is too. Is it possible to add to my existing prop?
lol 30 lwl 23 max rpm 3000, continuous the same
I have read that the clearance between blade tip and hull should be about 10% (min.) and better at 15% of the propeller diameter. Some also express this as multiple of the shaft diameter. Your boat might have a 1" shaft, and I would guess that the minimum clearance needs to be 2".
I have found that more blades gives more "push" for a given amount of HP, i.e. a three-blade prop will power a boat better in a chop than a two-blade.
It worked that way for our boat. We have used a two-blade fixed, two-blade featherer, and currently for several years a three blade fixed (narrow blade "sailor" prop). The current one gives us almost a half knot more in speed over the others, and of course costs us a half knot of speed under sail.
Everything's a compromise, as the old saying goes. :)
I am not a mechanic or a boat builder, so others here may have better information.
I think Loren said it: a 3-blade like mine will really help, but the cost is slower sailing, especially in light air.
I am often tempted by a folding 3- or -4 bladed prop, which for my boat pushes $4000 but does everything better. Even a new fixed prop is expensive.
Another way to look at it is that motoring at five knots doesn't seem bad for a 30-footer. I generally plan on only 6 with an E38.
meemee
e30
thanks Loren. How do you arrive at 2 inches with a 12 inch prop. I have a 3/4 shaft .Does that enter into the calculation or did you estimate 15 percent of 12 and round. A L S O...today i measured prop to rudder distance and thats NOT 4 inches. Perhaps that is why the 12 inch blade. I could modify the rudder edge by about two inches to allow a larger prop. Your take on thatis appreciared
Regards Meemee
