Results 1 to 5 of 5
Thread: Two holes in the Turtle
  1. #1
    Contributing Member III
    Join Date
    Nov 2001
    Location
    San Juan del Sur, Nicaragua
    Posts
    57
    I give up... what purpose do they serve? The wood is rotted out, should I take it out?
    Thanks for all the help.
  2. #2
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,160
    Blog Entries
    57
    Question My guess
    If you refer to two molding-in openings in the sea hood (aka hatch garage) these were intended for storage of sail ties.
    Never well water proofed underneath, moisture and rot would get into the core.
    If it were me I would cover the holes, and repair any water damage in that area before reattaching the "turtle".
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  3. #3
    Principal Partner
    Join Date
    Apr 2005
    Location
    Seattle, Wa.
    Posts
    414
    turtle openings
    When I had my turtle off, I cleaned out all the deteriorated plywood, covered the holes with1/4 inch starboard. The only thing I found the pockets were really handy for was to keep the beer from sliding off the cabin top.
    Harold & Jessie S/V Mischief Maker
  4. #4
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,399
    Blog Entries
    77
    I just two days ago painted the inside of the holes with Brightside. At some point an owner poured some filler in there , which self-leveled well as a surface coating of the original base. It isn't epoxy and needs to be repainted periodically, but it doesn't leak and the original design obtains.
    If you look down under the thread to "similar threads" there is a pretty amusing collection of puzzled owners all scratching our heads.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  5. #5
    Principal Partner footrope's Avatar
    Join Date
    Jun 2003
    Location
    Gig Harbor, WA
    Posts
    1,264
    Blog Entries
    11
    The good news is that these shallow plywood boxes in the "turtle" should not contribute to any leakage into the cabin. The original wood boxes had drain holes. The are connected only to the turtle. As long as you keep the drain holes at the edges of the turtle open, any leakage through the boxes will drain out. I put a new shallower bottom on mine a few years ago using a couple layers of fiberglass cloth and epoxy. Painted them with a good exterior latex house paint. Still looks good.
    Craig Davis & Ellen Le Vita
    1980 E38 "Pilot Project"
    Hull #20, Universal Diesel 5432
    Gig Harbor, WA
    In Puget Sound there are only two directions to go - North and South. That applies to the boat and the wind.
Similar Threads
  1. Holes that I don't know the use for.
    By Cruella in forum Design & Function
    Last Post: 07-10-2017, 11:24 AM
  2. 54 screw holes...
    By alcodiesel in forum Maintenance & Mechanical
    Last Post: 01-15-2017, 12:42 PM
  3. What are these holes for?
    By edokarura in forum Maintenance & Mechanical
    Last Post: 03-22-2014, 09:08 AM
  4. E34 drain holes
    Last Post: 01-03-2014, 01:10 AM
  5. What are the holes for ?
    By Sven in forum Design & Function
    Last Post: 10-13-2008, 09:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
