Results 1 to 7 of 7
Thread: E34 bow leak
  1. #1
    Contributing Member I
    Join Date
    Jul 2017
    Location
    New England
    Posts
    16
    E34 bow leak
    Hi All,
    If you were curious, after the seller agreed to replace the fuel tank {the weld on 3 support tabs had failed} and reinforce the heat exchanger mount we bought Hull #ERY34245E87. Very well maintained boat, can't be happier after crawling around her waiting for the new tank and finally setting sail and even being more pleased with the way she sails.
    Going in I knew there was a leak in the bow. I saw a thread about the anchor locker may be the culprite but cannot find that link again. my computer skills at work. Reason for leak may be that there are two 1.5" hairline/stress? deck cracks extending from the two lower, stern facing corners of the anchor locker hatch. Or as I read the pan leaks. Do I begin by pulling the pan out?
    Looking forward to any replies....I've been visiting this site and knowing that you are all out there made my decision to buy even easier.
    Best,
    Tom
  2. #2
    Join Date
    Apr 2014
    Location
    San Francisco
    Posts
    97
    Does the crack resemble the one in this thread?
    http://www.ericsonyachts.org/infoexc...-anchor-locker
    I did pull out the anchor pan and re-bed it. I also re-bedded the pulpit and that fixed a leak The most useful tool for taking the pan out was a wire brush. The cracks turned out to be surface cracks in the gelcoat. A substantial layer of plywood underneath was in good shape.
    Mike Field
    "Jenny" E35-3 #251
    San Francisco
  3. #3
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,341
    Blog Entries
    76
    The trick to finding things here is to use Google. Add to the keywords "ericson yachts."
    Also, once a good thread is discovered, a list of "similar threads" after the last post.
    There are lots of Ericson chain locker pan discussions because of leaks and because modification is required to install an anchor windlass.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  4. #4
    Join Date
    Apr 2014
    Location
    San Francisco
    Posts
    97
    Quote Originally Posted by Christian Williams View Post
    An even better technique, suggested by Christian in an early post, is when using the Chrome browser to use the keyword "site:ericsonyachts.org" along with your terms and google will confine it's search to the ericsonyachts.org site.
    Mike Field
    "Jenny" E35-3 #251
    San Francisco
  5. #5
    Contributing Member III
    Join Date
    Nov 2016
    Location
    Chicago, IL
    Posts
    42
    Quote Originally Posted by mfield View Post
    Hello: I posted "E34-II-Anchor-Locker-Leak-Into-V-Berth-Fixed" about my experience earlier this year.
    Brad
    NOMAD, Chicago
    1992 E34-II, Hull #004, Volvo 30HP Diesel
  6. #6
    Join Date
    Nov 2016
    Location
    Chicago, IL
    Posts
    42
    Quote Originally Posted by bkuchinic View Post
    Brad
    This may take you there directly:
    http://www.ericsonyachts.org/infoexc...-V-Berth-Fixed
    NOMAD, Chicago
  7. #7
    Join Date
    Jul 2017
    Location
    New England
    Posts
    16
    Thank all of you for the extensive information. I now have some concrete scenarios to investigate.
    Happy Thanksgiving to you and your families.
Similar Threads
  1. Leak
    By rootsey333 in forum Maintenance & Mechanical
    Last Post: 10-02-2017, 02:23 PM
  2. And...they still leak
    By trickdhat in forum Maintenance & Mechanical
    Last Post: 09-21-2017, 04:40 PM
  3. Well, gee - no wonder they leak
    By Mikebat in forum Maintenance & Mechanical
    Last Post: 08-01-2011, 01:50 PM
  4. E34 V-Berth Leak
    By maxhecks in forum Maintenance & Mechanical
    Last Post: 04-10-2011, 01:52 PM
  5. Help! I've sprung a leak
    By LarryBud in forum Maintenance & Mechanical
    Last Post: 10-17-2008, 10:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
