Wanted Stern Stanchions and Rail
Jeffrey Bond
I have a 1990 Ericson 34 that is in very good shape. Unfortunately a power boater came into the slip next to me to hot and bent my stainless steel stern stanchion. I am looking to replace as I do not know how to take the kink out of the bend.
If anyone knows how to straighten stainless steel, this would also be helpful.
Someone did a hit and run on my bow pulpit. It turned out to be surprisingly thin-wall tubing and pretty easy to bend back into shape. I bent one of the stanchions, while offloading the mast during haul out. IIRC, I just put it in the bench vise and carefully bent it back. But once thin-wall stuff develops an actual kink or crease, it probably has to be replaced. Or sleeved, but probably less hassle to replace.
Lots of stanchion parts at Defender and similar web stores. Also lots of older stanchions at local chandleries, wrecking yards, etc. Maybe a photograph of what you're trying to replace could be emailed to a few such places.
Jeffrey Bond
Thank you.
Good suggestions. I have photos. I should have chased my neighbor down for financial help but I was in a hurry. Instead I just moved to a different slip.
Here we have http://www.railmakers.com, there must be a similar outfit near you.
I just take the bent parts to them, they make a new one. I sketch a specialty part, such as grab rail on cabin house, they make it off the drawing.
Price reasonable, too. Bending, welding, polishing--no big deal to them.
A shop that specializes in tubing fabrication will cut out the kinked part. They will weld in a new section, and after buffing back to whatever version of a mirror finish that matches, you will be unable to find (!) the place that was repaired.
We had a number of little bends and old holes filled on both pulpits and several stanchions. All was polished out, and all the fixes were and are invisible.
