View Poll Results: Does your boat's boot stripe mark the waterline?
Voters
28. You may not vote on this poll
  • The boot stripe is high and dry above the water
    19 67.86%
  • The bottom of the boot stripe is right on the water
    8 28.57%
  • The boot stripe is submerged.
    1 3.57%
  • I'll have to scrape off some algae and get back to you...
    0 0%
Results 1 to 9 of 9
Thread: Poll: Where is your waterline?
  1. #1
    Curator of Broken Parts toddster's Avatar
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,300
    Blog Entries
    35
    Does the "boot stripe" mark the waterline on your boat?
    I've been revisiting boat specifications, trying to puzzle out a few things. Again.
    "Sailboatdata.com" says the displacement of an E29 is 7300 lbs.
    The manual downloaded from this site says the displacement is 8500 lbs.
    One travel lift operator said that the (pretty much emptied) boat weighed 10,000 lbs.
    Another operator said that 10,000 would barely lift the needle off the peg, so that's not very reliable.
    A previous owner has filled in the hollow part of the keel with... something. It could be lead... And I've since added a few hundred pounds of gear.
    And yet, the boat actually floats with the waterline pretty close to the bottom of the painted boot stripe. Maybe a tad lower with full tanks.
    As near as I can figure, it ought to take somewhere around 700 lbs to lower the water line an inch. So these discrepancies ought to make on the order of 2" of waterline change. On a boat this size, these differences are also large enough to screw up all the design "ratios" that people talk about.
    I've been contemplating loading up the boat for cruising, and started making a list. Just the weight of fuel, water, batteries, and ground tackle make quite an eye-opening subtotal! Just trying to figure out where the normal "zero" state is.
    s/v arcturus E29 #134
  2. #2
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    7,069
    Blog Entries
    55
    Red face Weight and Waterlines
    I have no exact response, but about a decade ago we had our boat lifted for a bottom job and I asked the Travelift operator if he had any idea what our weight might be. The boat would have been in what might be called 'light load' configuration, i.e. without all the additional stuff that would go aboard for a cruise. He said that based on the (old) load cell readout on the lift and his intuition from decades of running lifts he thought it was about 10.5 to 11K weight. Since the brochure weight is supposed to be 10600#, this was encouraging.
    As to the waterline stripe, it was always slightly submerged, even tho the PO had the bottom paint topped out at about one inch below the gel coated stripe. This would look great when afloat if the boat actually floated at that level, but the real-world waterline is and has been about an inch up onto the blue WL stripe... and that's where we have the bottom paint stopped for all of our paint jobs.
    "It is what it is" as a friend of mine is always reminding me.
    1988 Olson 34 #8
    Sail # 28400
    Betamarine 25 (new 2018)
    Fresh Air
    Portland, OR USA
  3. #3
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,300
    Blog Entries
    35
    Good point. I took the bottom paint right up to the edge of the gel-coated stripe. Probably a good thing.
  4. #4
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,300
    Blog Entries
    35
    Hmm... I just noticed that the drawing in the manual shows the boot stripe a couple of inches above the waterline. Consistent with the idea that the boat is already 1000 lbs over design weight.
  5. #5
    Contributing Member I
    Join Date
    Aug 2008
    Location
    MI
    Posts
    12
    Quote Originally Posted by toddster View Post
    Freshwater or saltwater? My E29 sits too low in the great lakes water.
  6. #6
    Join Date
    Jul 2011
    Location
    Oregon - The Gorge
    Posts
    1,300
    Blog Entries
    35
    Interesting thought, but freshwater vs sea water would only make a difference of about 20 lbs per inch of freeboard, or 3% difference.
    Now, an E29 in the Great Salt Lake could hold an extra 120 lbs per inch of freeboard! 17% difference.
  7. #7
    Join Date
    Apr 2015
    Location
    Pennsylvania
    Posts
    170
    I have a white waterline at the bottom of the boot stripe and it is right on top of the water.
    Don Moran, AKA Navman
    1986 E- 38
    S.V. The Optimist II
  8. #8
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,189
    Blog Entries
    74
    The previous owner brought the bottom paint up to cover the gel coat boot top. Still not high enough.
    I notice the new production boats have a bigger margin than old tradition. Some local boats have 8 inches of bottom paint showing.
    Good to note that a boat loaded beyond design waterline is going to be slower. Anybody racing should put the boat's waistline on a diet, rather than buying a bigger belt.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    "Alone Together--the Book" trailer here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  9. #9
    Contributing Member III
    Join Date
    Nov 2015
    Location
    seattle
    Posts
    49
    Smile Waterline stripe.
    Hopefully you will see it ABOVE the water line. Just sayins
Similar Threads
  1. E35-II measurements for best waterline
    By Leander in forum Design & Function
    Last Post: 07-19-2015, 05:03 PM
  2. Old Waterline?
    By footrope in forum Design & Function
    Last Post: 06-03-2008, 10:33 PM
  3. Waterline
    By wheelerwbrian in forum Maintenance & Mechanical
    Last Post: 01-10-2006, 08:08 PM
  4. E27 waterline
    By SteveS in forum Maintenance & Mechanical
    Last Post: 02-14-2004, 10:19 AM
  5. E35-3 - Waterline Off or To The Bootstripe?
    By Sean Engle in forum Design & Function
    Last Post: 07-05-2002, 11:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
