Results 1 to 8 of 8
Thread: Engine Compartment Insulation
  1. #1
    Contributing Member I
    Join Date
    Nov 2009
    Location
    Nanaimo, BC
    Posts
    10
    Hi, we have an Olson 34. We had to remove the old insulation from the engine compartment and wondered if anyone has any suggestions on what to replace it with. We race the boat so we're not interested in anything that's lead-lined! Any suggestions appreciated.
    Elaine Wade, Synergy, Nanaimo BC
  2. #2
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    6,953
    Blog Entries
    50
    Question
    Years ago the surface silvery mylar layer came loose and the foam was crumbling that was under it. It became kind of messy. I tore it all out. Except... the pieces that line the inside of the fiberglass steps. I was able to save that by re-adhering the whole edge with some new mylar tape. That steps molding would be really noisy without insulation.
    There is so much stuff fastened up to the walls around that engine that I have not yet figured out just how to re-insulate it.
    Let us know what solution(s) you come up with. I figure that all of EY boats from that era have the same sort of insulation. Hope to see some answers one of these days.
    Regards,
    1988 Olson 34 #8
    Sail # 28400
    Universal M25XP
    Fresh Air
    Portland, OR USA
  3. #3
    Contributing Member III
    Join Date
    Nov 2016
    Location
    Chicago, IL
    Posts
    41
    Gents, I have the same problem and may try one of these products (searched "engine compartment insulation" at defender.com).
    http://search.defender.com/?expressi...lation&x=0&y=0
    Best regards,
    Brad
    NOMAD, Chicago
    1992 E34-II, Hull #004, Volvo 30HP Diesel
  4. #4
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,009
    Blog Entries
    73
    The primary sound insulation on my boat is the big front panel of the engine compartment (under the ladder) and the top panel, which forms the top of the box.
    Not much room, but the Previous Owner seems to have placed what insulation material would fit against the panel backs and then covered it all with the Mylar tape in the Defender link above.
    It seems to work, looks nice and shiny.
    My real "insulation" is a dish towel under the three stove burner grids, shims for the barrel bolts that hold the engine box panels on, and small pieces of foam glue under lazarette lids.
    I don't mind the diesel noise, it's the buzzing and rattling of all that other stuff.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    "Alone Together--the Book" trailer here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  5. #5
    Grizz Grizz's Avatar
    Join Date
    Jun 2010
    Location
    Chicago
    Posts
    152
    Sound Down? The on-going attempt...
    As Loren alluded, the OEM 'stuff' Ericson used on these Olsons is flaking & crumbling, offering little decibel resistance and creating a big mess whenever it's touched, rubbed or breathed on.
    The 1st attempt, surprisingly successful (as that rarely happens on the 1st go) was to re-insulate the small panel that allows access to check the oil level and murmur sweet nothings in the girl's ear, the latter in the hope that Iron Genny (she's ok with that nick name) will remain reliable.
    Because that small test worked (neat, tidy, not crumbly), the next was the removable tray above the engine. Just larger, but the same installation system as the little panel.
    Next up, while cringing, was the port/sb side surfaces, accomplished by removing as little as possible of the wiring and control cables to affix the insulation in tight quarters (at best) or 'not a chance' (at worst). The decibels increased as the 'sweet murmurs' changed to questions of linage and blaming those responsible for naval design.
    Eventually, port and starboard received all new sound dampening material. The dB App on my Apple proved there is a difference (wonderful thing, at times, this technology stuff!).
    The final step, which hasn't happened, WAS an attempt to pull the fiberglass steps, schlepp it home to the shop last winter and redo all that material, comfortably, with plenty of room and time. Unfortunately, that same naval architect somehow figured a way to get the steps in, but allowed no way for them to be removed (like building a boat in a basement). A friggin' 3-d Rubik's Cube that proved unsuccessful, no matter how the step assembly was rotated, positioned or started. Nightmare, and then surrender. Not happening, not in the home shop. Plan B.
    I sprung for the recommended tape, trying to avoid repeating the process again due to 'cheap'. Right decision.
    Next up...another attempt to locate the low oil pressure buzzer. The light works, but no sound, which, given a choice, the inverse would be preferred. Oh well...
    Hope this helps someone. Take care.
    1989 Olson 34 #9
    Sail #34109
    Shoe String
    Chicago, IL USA
  6. #6
    Principal Partner
    Join Date
    Mar 2006
    Location
    Winters, Boca Raton, Florida, Summers Glenview(Chicago) Illinois.
    Posts
    302
    On my 35-3, the insulation was in tatters....perished...a total mess....getting it all off and cleaned up was a nightmare, as the PO tried to glue the old stuff back on piece by piece.....
    After cleaning it all off, and a couple of coats of slathered on varnish for water & moisture proofing, I cut an acoustic ceiling tile to the proper size for both the front panel, and the top......sealed the edges with duct tape, and six wood screws in each to fasten, and they have been there for ten years.....
    I seem to remember that when I did this the cabin was much quieter......but that was then.....and my hearing has diminished....so the combination is working!
    Mort Fligelman
    A Capella
    E35-3 1987
    Glenview, IL
  7. #7
    Join Date
    Aug 2005
    Location
    Minneapolis, MN
    Posts
    144
    Our engine compartment insulation was failing back in the early 90's. Our then current service department manager had previously worked building some powerboats. He recommended a 1 inch soft foam that was covered with about and 8th of an inch of white vinyl. He ordered it for me, so I don't know where it came from, but it's worked great since the early 90's. I'd definitely recommend it.
    Name:  Engine Compartment insulation.JPG
    Bob and Sandy Robertson
    Anticipation
    Ericson 38-200, 1988
    Bayfield, WI
  8. #8
    Principal Partner GrandpaSteve's Avatar
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    304
    Sound reducing tiles
    Quote Originally Posted by Bob Robertson View Post
    I got tiles here for my 32-III engine box:
    https://sailorssolutions.com/?page=P...ils&Item=SPM01
    1987 E32-III "Glory Days"
    Hull #711
    Slip in Rock Hall MD.
    Home in Downingtown PA.
Similar Threads
  1. E35 Engine Compartment Access "port"
    By EMKoper in forum Maintenance & Mechanical
    Last Post: 02-07-2016, 06:48 AM
  2. battery compartment
    By drcam1 in forum Maintenance & Mechanical
    Last Post: 11-20-2012, 11:17 AM
  3. Engine room insulation
    By Bob Brigham in forum Maintenance & Mechanical
    Last Post: 09-04-2012, 06:15 PM
  4. Replacing Recessed Engine Instrument Panel Compartment
    By Rob in forum Maintenance & Mechanical
    Last Post: 11-18-2006, 06:02 PM
  5. engine compartment cooling ?
    By CaptnNero in forum Design & Function
    Last Post: 08-02-2006, 06:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
