PHRF cert for 32-III?
bgary
Advanced Beginner
There's a relatively low-key singlehanded race up here in the fall, and it's whispering in my ear. I miiiiight be leaning toward entering in a non-spinnaker division, just for grins.
In order to do that, I need to get a PHRF cert.
Anyone have one from which I can copy some measurement numbers to get the process started?
Bruce
gadangit
Hi Bruce-
You can always check sailboatdata.com for dimensions. We have two 32-3 down here that race non-spin, one is a shoal draft and not sure about the other. Shoal draft rates 199 and the other is 187.
What is the race?
Good luck!
Chris
Bruce
bgary
Advanced Beginner
Thanks. PHRF-Northwest wants a variety of measurements to the hundredth of a foot. Sailboat data has some of the rig measurements (and I have the basic boat dimensions), but would love to see a cert just to know whether the sailboatdata numbers are reliable. Fallback is to actually have someone measure the boat, but that's more serious than I feel like being at this point.
What is the race?
https://www.styc.org/race_info/Single-Handed Race/index.shtml
Scott B.
Member
Hi Bruce,
I just went through the process of getting a PHRF rating for my E-25+, and it was a fairly simple process. The standard rig dimensions for your boat should be readily available on the web from a variety of sites. What may change your rating (from the standard for the boat) are the dimensions of your sails and any modifications to the boat from its original factory layout. The hard part is really just laying out your sails and taking the required measurements according to the directions on the form (plus a few other measurements, spinnaker pole length, etc). It probably took me a couple of hours to leisurely get my sails laid out and take all the measurements, but if you're in a hurry, you could probably get it done much quicker than that. It helps to be in contact with a handicapper from a local yacht club in case any questions arise, so you may want to consider joining a club (if not already a member of one). Then make at least two copies of the completed form, and send one to the PHRF-NW (with the required payment) and the other to your club's handicapper (if you have one)...and then wait. I'm still in the waiting phase. My handicapper came up with my boats rating quickly, but he can't officially issue a certificate until everything clears with the PHRF-NW.
What you'll need: a large flat area; a 50' or 100' tape measure; and three stakes with bungee cords (to apply tension to the sails). A helper is not necessary, but would make the job much faster and easier.
Also, if your are only planning to do that one race, another possible option is to contact the handicapper or race director from the sponsoring club to find out whether they'd be willing to issue you a one-time temporary PHRF rating just for that race. I've heard of that being done, but you may still need to measure your sails.
-- Scott
