Results 1 to 12 of 12
Thread: how to lower dinette table on '85 E35-3 ?
  1. #1
    Join Date
    May 2017
    Location
    Westport, CT
    Posts
    3
    Greetings
    Anyone have the secret to lowering the dinette table on an E35-3 ? Mine has a black knob on a lower collar that keeps the table from swiveling, but does not allow the table to lower into a berth. Any ideas please ?
    thks !
  2. #2
    Join Date
    Jun 2014
    Location
    Channel Islands Harbor, California, United States
    Posts
    106
    Hmmm...same knob should adjust height, at least that's how it works on mine.
    I'd guess you have an indent that is keeping the table from swiveling, but not lowering. Are you backing the knob all the way out?
    Can you try lifting instead of lowering?
    September Sun
    ERY35240D686
  3. #3
    Join Date
    May 2017
    Location
    Westport, CT
    Posts
    3
    yes, I backed the black knob all the way out - nothing. When I try to lift the table it seems to hit something and stops. And no luck when trying to push the table down either. It seems to be a mystery....I'm fairly hands on, but either a malfunction or something else.
  4. #4
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    6,796
    Blog Entries
    49
    Question
    I have seen other boats with similar dinette style table where the knob was loosened and the table lifted off. Then the pillar was lifted out of the base and stored. Step #3 was then laying the table top down on some perimeter supports and putting a "fill cushion" over it to make up a sleeping berth.
    1988 Olson 34 #8
    Sail # 28400
    Universal M25XP
    Fresh Air
    Portland, OR USA
  5. #5
    Principal Partner Cory B's Avatar
    Join Date
    Apr 2005
    Location
    Portland, OR
    Posts
    471
    On our 35-3 it lifts up just as Loren describes. It jams a little and sometimes you have to give it a really strong tug while twisting a little at the same time.
    We have a knob on the upper collar as well, which you should too if your's is designed to be lifted up.
    Cory
    1984 E-35III #163 "Balancing Act"
    Portland, OR
  6. #6
    Join Date
    May 2017
    Location
    Westport, CT
    Posts
    3
    hmmm, Mine only has one collar at the bottom. Maybe a few squirts of WD 40 and I'll try to lift it out. Thks very much for your suggestions !
    Randall
    'Endless Summer'
    '85 - E35-3, #201
  7. #7
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Pacific Palisades, CA
    Posts
    2,731
    Blog Entries
    71
    The 32-3 had a hole in the floorboard underneath. You lowered the tube into the bilge.
    Since these base/tube connections are famous for twisting, a PO may have "sealed" it in place. I'm about to put a set screw in mine, so it doesn't knock out of true.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    "Alone Together--the Book" trailer here
  8. #8
    Join Date
    Jun 2009
    Location
    Long Beach, CA
    Posts
    142
    How to keep from breaking your table edges
    When you are able to get the table up and off of the post that it came with, you can drop the table into the opening formed by the seats to make a bed. As suggested above there is a lip that the table sits on.
    If you have kids with no sense or very large sailors on board that table can take a lot of abuse in the "bed" position. After repairing ours twice, I found a matching diameter aluminum tube and cut it to length to fill the gap between the table and the base in the "bed" position. Have not had a n issue since.
    Best,
    Matt
    1984 E35-III
    Former Partner S/V "Wind Chaser" #187
    Long Beach, California
  9. #9
    Sustaining Partner GrandpaSteve's Avatar
    Join Date
    Jan 2013
    Location
    Downingtown, Pa.
    Posts
    273
    Maybe a PO put something inside the post to hold it up steady. Try pulling the table out of the post to take a look.
    1987 E32-III "Glory Days"
    Hull #711
    Slip in Rock Hall MD.
    Home in Downingtown PA.
  10. #10
    Contributing Member I
    Join Date
    Jul 2011
    Location
    Knoxville TN
    Posts
    16
    small pin in mine
    For my E32-3 table, I do have the black knob, but I also have a small hole in the shaft (on both sides) and a thin metal pin poking through it that then rests on the top of the outer tube on both sides.
    I guess the PO felt the friction knob wasn't holding it up so he put this pin in place. Or, it's there so the friction knob can be backed off at all times to let the table swivel freely as needed.
    E32-3 #655
    Traveller
    Knoxville, TN
  11. #11
    Join Date
    Apr 2014
    Location
    San Francisco
    Posts
    75
    dinette table
    The table top should slide down until the table meets the teak cleats. However, the single pole table is such a wobbly affair that I have two hose clamps around it to try and stabilize it. In your case I suspect a previous owner glued the whole thing together.
    Mike Field
    "Jenny" E35-3 #251
    San Francisco
  12. #12
    Join Date
    Apr 2017
    Location
    Boston - Maine
    Posts
    13
    possibly corroded
    My 84 35-3 table lowers (and raises) just by loosening the black knob. I think the table swivels as well when the knob's not tight. The pole on the table remains on the table in both positions. I imagine your table might have been left in the up-position for years and the aluminum (I think) pole has corroded into the base fitting a bit. Perhaps take out the black knob entirely, heat the base with a torch (not too hot!). That might loosen her up a bit. You might even be able to unscrew the mechanism from both table and boat and use a hammer-drift to tap the pole out from the bottom of fitting on a bench. Could be there is a lip or something on the pole that's catching. Good luck! I haven't used the table as berth yet (just bought the boat) but I am really looking forward to it.
Similar Threads
  1. Dinette Table question on my E-27
    By joe-fran in forum Design & Function
    Last Post: 06-04-2008, 12:23 PM
  2. 1974 E-32 dinette table, etc.
    By Bill Beatty in forum For Sale & Wanted
    Last Post: 01-31-2008, 10:38 PM
  3. E32-3 Dinette Table Lift Strut
    By newgringo in forum Maintenance & Mechanical
    Last Post: 02-25-2007, 05:32 PM
  4. Dinette Pedestal Removal
    By vernon kleist in forum Maintenance & Mechanical
    Last Post: 05-22-2006, 06:13 PM
  5. Wanted - Table Pedestal for Dinette 1976 E 32
    By scourge in forum For Sale & Wanted
    Last Post: 01-20-2005, 09:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
