Hi all,
So I am about to do a survey on a 1987 381. It has water staining around the mast area on the sole (don't think it is rotten yet). I've read the threads here on that. I also noticed the aft end of the keel with a thin separation crack from the hull....I found some threads on that...although that is starting to scare me.
Anything else I should be aware of or should I cancel the survey now??!!! I'm just concerned about winding up with more problems than I can deal with right now.
Gerhard
Gerhard
