Results 1 to 11 of 11
Thread: 84 35-3 sheave sizes?
  1. #1
    Contributing Member I
    Join Date
    Oct 2015
    Location
    TN
    Posts
    13
    Do any E 35-3 owners know the dimensions for the mast top sheaves? I replaced wire/rope halyards with all rope and have trouble with the splice going over the sheave.
    I won't be pulling the mast any time soon, so trying to figure it out ahead of time.
  2. #2
    Principal Partner Cory B's Avatar
    Join Date
    Apr 2005
    Location
    Portland, OR
    Posts
    470
    Hello Joe,
    I don't recall exactly. When we bought our boat we pulled the mast. At the time the biggest line I was comfortable with was 3/8", although you might be able to use 7/16". Instead of splices I've just used knots, and cut them off ever few years to move shift all of the wear points. I think the problem with some splices is that not only are they wider, but they aren't as flexible (at least initially) and can have trouble fitting around a sheave. We used "modern" line which was so overstrength that I wasn't concerned about the "weak" knots. Its worked well for us.
    Cory
    1984 E-35III #163 "Balancing Act"
    Portland, OR
  3. #3
    Join Date
    Jun 2014
    Location
    Channel Islands Harbor, California, United States
    Posts
    96
    Can you check against your mast measurements?
    Kenyon 4873?
    http://www.rigrite.com/Spars/Kenyon_...3-cruising.php
    If so, scroll down for the sheave size.
    Max
    September Sun
    ERY35240D686
  4. #4
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    6,726
    Blog Entries
    49
    Lightbulb
    When I changed out the original wire/rope halyards in our '88, with a Kenyon spar, I tried 3/8", and it works... but really has some noticeable drag where it goes thru the masthead sheaves. When I went to 5/16" very low stretch (T-900) line, no more problem.
    1988 Olson 34 #8
    Sail # 28400
    Universal M25XP
    Fresh Air
    Portland, OR USA
  5. #5
    Principal Partner Tom Metzger's Avatar
    Join Date
    Oct 2002
    Location
    Clifton Park, NY
    Posts
    1,352
    I had a 7/16" main halyard for many years that had no problem at the masthead. It died from chafe at the lower mast exit in 2015. There was no wear evident at any other location.
    I did replace it with 3/8" NE Ropes VPC from Milwaukee Rigging which has very good prices. Interestingly, their Ebay store is much more expensive than their regular store. I have bought from them before and have had good service.
    Tom Metzger
    E-34 Xanthus
  6. #6
    Advanced Beginner bgary's Avatar
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    578
    Blog Entries
    16
    I don't know what size the sheaves are for a 35-III, but I'll share that the sheaves on a 32-III are 2.5" diameter, 0.475" wide and nominally sized for 3/8" line.
    All my current halyards are 3/8", all rope. I've got a spin halyard that is telling me it wants some attention this year, and I'm probably going to replace it with 5/16" VPC so that it runs free with minimal resistance from masthead or exit slot.
    My main and jib halyards will likely stay 3/8"... jib only goes up and down a few times a season, the rest of the time it is furled; the main halyard stoppers are sized for the 3/8" line and it ain't broke, so no need to change it.
    $.02
    Bruce
    ETA: photo of 32-III masthead with 3/8" halyards. I think I have a photo of one of the sheaves, too, if that's of value...
    "Makana" (ex-Thelonious)
    1985 Ericson 32-III #604
    Makana blog: here
  7. #7
    Sustaining Partner EGregerson's Avatar
    Join Date
    Mar 2003
    Location
    Newport News, VA
    Posts
    298
    sheaves
    when i swapped out a couple of my sheaves (like 10 years ago) i noted that they had a 'V' shaped design to accommodate the wire; discussions suggested that with a wire to rope conversion, u should change to the 'U' shaped sheave; also to avoid any potential burr damage to the new rope.
    a little more research: cruisersforum: the swap to rope while retaining the original V shape reduces the safe working load by compressing the rope in the V groove.
    Valinor 1987 E34 Hull#243
  8. #8
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Pacific Palisades, CA
    Posts
    2,591
    Blog Entries
    71
    Many of us have been advised that the wire sheaves accept rope with no problem. Worth further research.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    "Alone Together--the Book" trailer here
  9. #9
    Join Date
    Aug 2015
    Location
    Everett, WA
    Posts
    578
    Blog Entries
    16
    Yes, all-rope halyards will work fine over sheaves made for wire/rope halyards.
    Makana blog: here
  10. #10
    Contributing Member II
    Join Date
    Aug 2016
    Location
    Lake Texoma, Texas
    Posts
    21
    Up the mast
    Quote Originally Posted by Christian Williams View Post
    After replacing my Halyards I went up the mast to do some work and decided to inspecte the sheaves accepting the rope. I can say on my '83 35-3 I have no issues with the current set up using all rope.
    Darrel
    E35-3 #154
    s/v Sunflower
  11. #11
    Join Date
    Oct 2015
    Location
    TN
    Posts
    13
    Thanks for all of the input.
    Very much appreciate it.
Similar Threads
  1. hose sizes on E38-200
    By trenton in forum Maintenance & Mechanical
    Last Post: 08-22-2015, 10:06 PM
  2. Why so many sizes?
    By mherrcat in forum Design & Function
    Last Post: 04-17-2009, 08:51 AM
  3. Cushion sizes
    By e38 owner in forum Design & Function
    Last Post: 06-05-2006, 09:24 AM
  4. Luff tape sizes?
    By Mike Thomas in forum Maintenance & Mechanical
    Last Post: 01-09-2006, 03:12 PM
  5. Sail sizes for Ericson 36C
    By Ian Hay in forum Design & Function
    Last Post: 11-20-2004, 09:32 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
