907Juice
Continuously learning
While the boat is out of the water I want to replace the stuffing box and pull the engine to work on motor mounts and generally clean it up. The connection is quite pitted and will likely need replacing. But before that I need to disconnect it. I know I need to remove the 4 bolts connecting to the transmission, but what is the single bolt going into the side of it? Can I work that loose and slide the shaft out? It would be much easier to work on it on a bench somewhere. Anyway any help would be nice.
Juice
Juice
