Results 1 to 12 of 12
Thread: Used sails from E-38
  1. #1
    Principal Partner footrope's Avatar
    Join Date
    Jun 2003
    Location
    Seattle, WA
    Posts
    1,202
    Blog Entries
    10
    I have three used dacron sails of indeterminate age that I got with the boat in 2003. I have purchased a new 135% roller-reefing genoa/jib and a new main, so these are surplus. None of them are torn.
    300 sq. ft. main - some stains, 2 reef points
    300 sq. ft. jib - about a 90% size, some stains, not roller reefing
    155% genoa - I have hardly used it since it can't be effectively furled/reefed to a smaller size when a breeze kicks up suddenly
    All are in bags. I am in the Seattle area. I am also trying to donate them, but I've just started to look at that option.
    Make offer.
    Craig Davis & Ellen Le Vita
    1980 E38 "Pilot Project"
    Hull #20, Universal Diesel 5432
    Seattle, WA
    Somebody once said "It's an old boat and therefore resistant to change."
  2. #2
    Join Date
    Jun 2003
    Location
    Seattle, WA
    Posts
    1,202
    Blog Entries
    10
    Sails were given away
    Not available any longer. I found a loft that would take them and hold them until a sail-re-user could come pick them up.
    I called Seattle's Center for Wooden Boats (cwb.org) twice and never heard back from them.
    Seattle, WA
  3. #3
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    2,870
    Blog Entries
    73
    I accepted the princely sum of $200 from Minnie's (local yacht surplus) for my old main and 135 genoa. They were not bad, probably 10-12 years old, full battens.
    "We are so full of sails we don't even have room for them," the owner said. "So sorry, I know they're worth more. Here, take a free T-shirt".
    Our old sails are shed awnings or drop cloths or whatever you can think up. Unless you have a needy and similar boat nearby, no market value at all.
    Seems a shame.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    "Alone Together--the Book" trailer here
  4. #4
    Sustaining Member kiwisailor's Avatar
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    83
    Blog Entries
    11
    Quote Originally Posted by footrope View Post
    Make offer.
    I have what I believe may be the original E38 Ulmer (UK) sails that I haven't even pulled from their bags yet as they appear to have stitching that's fallen apart and I will probably look to off load them as you have. I then have a set of 15 year old North Sails that were rigged and are probably OK for now, they're currently at the local North Sails loft being winter serviced.
    I'd be very interested to know what size genoa you selected and why, also the brand of sails and cost if that's OK.
    Mike
    Sherene & Mike Taniwha
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
  5. #5
    Join Date
    Mar 2014
    Location
    Maryland
    Posts
    139
    Blog Entries
    1
    used sails
    I am currently looking for a 135% Genoa for Discovery, a 1983 30+.
    MJS
  6. #6
    Join Date
    Jun 2003
    Location
    Seattle, WA
    Posts
    1,202
    Blog Entries
    10
    Quote Originally Posted by kiwisailor View Post
    Mike
    Hi Mike,
    I hope this info helps.
    I didn't do a detailed comparison of the various local sailmakers and spreadsheet it to compare the costs and claims. I selected North because I liked their cruising laminates and wanted to try them after racing on other people's boats with laminated sails. I did investigate heavy duty dacron through the rumor mill, but I didn't get an estimate. North's quotes were within my budget and I went forward (this was before I retired!).
    I talked to the sailmaker quite a bit about the 100% jib vs. 130% genoa. I had a hard time with the 155% during the first season with the boat. So I used the 100% almost exclusively after that and liked it. My E38 with the old main and 100% jib didn't sail well to windward unless the wind is at least 10 knots. I am hoping that the laminate at 130% will drop that figure down to around 8. We'll see.
    My North main is full batten with two reef points, and I installed a Tides Marine track ($600) in place of the aluminum insert that was in the mast. The track was a recommendation of the sailmaker and it is working out well. I can hoist it almost to the top myself without a winch, jacking it at the mast. It falls easily into my lazy jacks. The spec is as follows: 7.4 oz. NLXW+360+SISIL. It is the standard 300 sq. ft. triangular main.
    The jib/genoa is a furling 130%, 7.0 oz. NLXW SISIL. It is designed to be roller furled and is marked to help me hit approximately 90% at the first reef.
    The total cost for both sails was just under $14,000, including 9.5% sales tax, in 2014. I did get a discount - they were running a "sale" at the time.
    This picture was taken while checking the main's reef points and running rigging. Wind was under 10 knots. I don't have a shot of the jib yet.
    Click image for larger version.
    Last edited by footrope; 04-21-2017 at 12:51 AM. Reason: Clarify roller furling jib
    Seattle, WA
  7. 04-30-2017, 09:25 AM
  8. #7
    Join Date
    Apr 2012
    Location
    Salem, Mass
    Posts
    109
    Seabags
    There is a company in Portland ME called "Seabags" that will take your sails and make you a free custom bag in return. I have a duffle with the logo from my first boats main and a large tote with the Ericson logo from our current boats original main.
  9. #8
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    83
    Blog Entries
    11
    Hi Mike,
    Hey Craig, thanks for the detailed feedback!
    Your 130% looks to be a good choice, I'll see how my 150% performs this summer in the Long Island Sound breezes before making any decision. Videos of the Tides Marine track performance look impressive when hoisting or dropping the main. I've a Dutchman system so will just have to see how that performs this season.
    Cheers.
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
  10. #9
    Join Date
    Aug 2016
    Location
    Groton, CT
    Posts
    83
    Blog Entries
    11
    Quote Originally Posted by lnill View Post
    I'll look into Seabags as they have a local shop in Mystic, CT. It looks like if they accept the sail they can be dropped off at a local shop.
    1981 E38 "KIWI"
    Hull #53
    Groton, CT
  11. #10
    Senior Moderator Loren Beach's Avatar
    Join Date
    Dec 2000
    Location
    Portland, OR. Columbia River
    Posts
    6,878
    Blog Entries
    50
    Cool SA note
    Cheers.
    And, while pondering "how much is enough" headsail, remember that the picture of our boat doing over 7 Kts to hard on the wind in about 12 kts true shows a 95% composite jib with three battens.
    Your BK-designed hull is, after all, Very easily driven, unlike the newer vacation homes marketed as sailboats.
    http://www.ericsonyachts.org/infoexc...chmentid=19173
    1988 Olson 34 #8
    Sail # 28400
    Universal M25XP
    Fresh Air
    Portland, OR USA
  12. #11
    Amazingly Still Afloat
    Join Date
    Nov 2013
    Location
    Northern Chesapeake Bay, MD
    Posts
    140
    Blog Entries
    8
    Uses on your boat
    I used my old mainsail to make a wheel cover, binnacle cover, winch covers, and a spinnaker for the dinghy. Sprayed like crazy with scotch guard. They've lasted two years in the Mid-Atlantic so far. Probably need some type of UV protection spray further south.
Name:	Small dinghy spin.jpg
ID:	21945Click image for larger version.
ID:	21949Click image for larger version.
Name:	wheel cover.jpg
ID:	21950Click image for larger version.
  13. #12
    Join Date
    Jun 2003
    Location
    Seattle, WA
    Posts
    1,202
    Blog Entries
    10
    Kudos!
    Quote Originally Posted by Macgyro View Post
    Love that spinnaker for the dinghy idea. Very good uses for old sails. I kinda wish you'd posted this a month ago, but then I think of the space they took up in my garage and ... it was ok to donate them for something other than the landfill. Supposedly the company will use them for bags and such, as the company in Maine does. I have heard from a sailmaker that there is a used sail business in Friday Harbor, WA. But you have to deliver to them.
    If you have more cloth maybe you could make one of those mortar-deployed kite spinnakers like our fishy friend in Waterworld used.
    Seattle, WA
Similar Threads
  1. new sails
    By Randy Rutledge in forum Cruising & Racing
    Last Post: 05-18-2011, 08:14 AM
  2. WTB: E29 Sails
    By PatrickMcHugh in forum For Sale & Wanted
    Last Post: 08-13-2009, 10:15 AM
  3. Replies: 6
    Last Post: 06-20-2007, 09:04 PM
  4. FX Sails
    By Sailsteve in forum Maintenance & Mechanical
    Last Post: 12-16-2006, 12:34 PM
  5. Need sails for 38-200
    By palmerjv in forum For Sale & Wanted
    Last Post: 07-06-2005, 12:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
