Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Companionway Step Repair
  1. #1
    Contributing Partner lonokai's Avatar
    Join Date
    Feb 2016
    Location
    Dana Point, California
    Posts
    124
    I continue efforts to fix things on Lono Kai. I am alas, not a good handyman, but I am trying.
    Today: the companionway steps. I have been sanding them down and removing the old paint from the PO. Today I took off the metal (steel?) plates on either side of the top of the steps.
    This revealed some rotted wood and a crack on one side (see the photos). The crack extends about 24 inches down the steps. The top of the crack was filled with silicon and the wood does separate if pulled. The opposite side is fine. I assume the PO used the metal plats on both sides to reinforce the stairs.
    I never really liked the steel plates, and I do not relish the thought of having to sand all the paint and rust from them, but I am concerned about the wood now. I'm thinking I will do the following;
    Clean out the previous repair work (silicon and whatever else), sand everything down and then put CPES EPOXY just to the cracked areas in the hope of strengthening the wood there.
    Sand down (or clean) the steel plates. Paint them silver. Place them back onto the steps with CPES EPOxY between the steel and the wood. When all have cured, CPES the whole thing, then varnish and hope they hold.
    Any thoughts on the efficacy of this?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	20051   Click image for larger version.
ID:	20052   Click image for larger version.
ID:	20053   Click image for larger version.
    Eric Gordon
    1975 Ericson 27, Yanmar 3GM30
    Dana Point, CA
    "Sea Star"
    Hull #721
  2. #2
    Join Date
    Feb 2016
    Location
    Posts
    124
    BTW, I realized I forgot to resize the photos and orient properly....sorry
    Attached Images Attached Images
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  3. #3
    Principal Partner Afrakes's Avatar
    Join Date
    May 2009
    Location
    Port Kent , NY 0n Lake Champlain
    Posts
    607
    Mounting brackets
    The metal mounting brackets should be plated bronze or brass. Sometimes the pitted and corroded plating makes them appear to be rusty. Injecting thickened epoxy into the tracks should be enough to restore integrity to the wood.
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
  4. #4
    Join Date
    Feb 2016
    Location
    Posts
    124
    Thanks Al. I am thinking I might drill some holes into the backside of the steps to get more epoxy in there....see diagram
    The dotted lines are where I would drill holes.
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  5. #5
    Moderator Christian Williams's Avatar
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,919
    Blog Entries
    78
    Except for the tops, it looks like the ladder will clean up well and take varnish to look good.
    The steel plate was overkill and poor choice of material. You can strengthen that side by other means, suggested above.
    But, appearance-wise, I don't think the tops will look good in varnish, even with a lot of sanding and filling and bleaching.
    If it were me, I would paint the tops (only), giving the ladder a rather dashing appearance, like Fred Astaire upsidedown (reference is to his white spats).
    Even for painting, the tops will take filling and smoothing for a uniform surface.
    When I redid my ladder recently, I used a heat gun to remove old varnish.
    If there are stains still marring the surface, Oxalic acid wood bleach is effective.
    Is prep complete and a surface ready for varnish? A swipe with an alcohol rag previews exactly how it will look.
    Thelonious II, E381 hull 513 (1984) Universal 5432
    Table of Contents for Thelonious Blog here
    Videos: http://www.youtube.com/c/ChristianWilliamsYachting
  6. #6
    Join Date
    Feb 2016
    Location
    Posts
    124
    Thanks Christian. Just to clarify...you mean the whole top above the step on all sides... (see arrows)
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  7. #7
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,919
    Blog Entries
    78
    Yes, exactly.
    If when you finish the reinforcement the wood looks OK, maybe you can still varnish it. But if it looks beat up, stained and ugly, in distinct contrast to the rest of the ladder, the alternative is paint as an "accent" there.
    It would be easier just to varnish it all, if it turns out not too bad.
    The white stuff on the rungs--looks like sealant? what glue cures white?-- needs to come off without a trace before varnish.
  8. #8
    Join Date
    Feb 2016
    Location
    Posts
    124
    Its looking good right now...not perfect...
    So, I have the "Layup and Laminating Epoxy," Parts A and B, which I will use for the repair.
    Afterwards, Thought I would "paint" the whole top with the CPES,
    THEN Varnish it all.
    It might not look absolutely perfect but should be better than government work.
    BTW, the PO painted all the steps white. Some of it has seeped deeply into the wood. I might have to live with SOME faint white specks here and there and those lines along where the two pieces of wood join.
    Now, Mr. Smith's site says that you should use the CPES as the first step, then move on to other products......I was going to use the Laminating Epoxy first.
ID:	20058   Click image for larger version.
Name:	stair top ready for repair.jpg
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  9. #9
    Principal Partner
    Join Date
    Feb 2001
    Location
    So Cal
    Posts
    651
    Blog Entries
    3
    I would not use cpes to effect repairs. WEST epoxy would be my choice. Lay it in the crack with a syringe, and then clamp it up.The bond
    created will be stronger than the wood.
    Martin
  10. #10
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,919
    Blog Entries
    78
    That's going to look fine with varnish. It will have character.
    Your plan is sound, but since we're discussing this repair among us amateurs, here's what I would do.
    Since the issue is just a crack in the wood, I'd drill ( from the back) for three #12 stainless wood screws to draw the pieces together and keep them there. Expoxy is optional.
    I might use a 3/8ths forstner bit to insert the screws, then plug them with 3/8th plugs.
    For the holes and gaps remaining, I would (keeping this to myself since it isn't nautical) get from a hardware store some plastic wood or other mahogany-colored fill and fill the holes and cracks.
    Sand and apply at least four coats varnish, the first thinned 50 percent so it will absorb.
    I wouldn't bother with CPES, myself. The screws provide mechanical strength and CPES is for wood that's gonna get wet or needs to be hardened up.
    Many ways to do it, just thuoght I'd give my approach.
  11. #11
    Join Date
    Dec 2000
    Location
    Santa Monica CA
    Posts
    1,560
    Sanding those steps.
    Eric,
    I have a Bosch corner sander with the triangular random orbit pattern that I'd be glad to lend you. As a matter of fact, I have two of them so probably would't miss the one. They work like a son if a gun and would make short shrift of the remaining white paint. Have you considered Gorilla glue for that long split in the wood? The rest could be filled/repaired with a slurry of thickened West System 105 and gobs of mahogany saw dust. Let me know if I can help, Glyn
  12. #12
    Innocent Bystander tenders's Avatar
    Join Date
    Jun 2006
    Location
    Harlem Yacht Club, City Island, NY
    Posts
    1,091
    I agree with Martin that CPES is a waste of time for this. Actually I think it is a waste of time for most everything. I have a quart I bought years ago for some repair I can't even remember anymore and it has never been used. I have always found some other better approach, and in this case I think Martin's suggestion is that better approach. In fact it is like the Six Million Dollar Man: better, stronger, faster. (CPES takes a long time to cure.)
    1969 Ericson 32 #112 • Atomic Four
    City Island, NYC
    “Muxie Duxer”
    Hair by Mr. Gigi
  13. #13
    Join Date
    Feb 2016
    Location
    Posts
    124
    Smile
    OK, Thanks to all of you. As it turns out, I did NOT use CPES. I did however use the Rot Doctor's Laminating Epoxy, simply because I am 100 miles from the boat and nowhere near anywhere to get some West epoxy...etc,,,
    In any case, I sanded everything down and filled the larger space with the epoxy. IT has dried extremely hard and is holding together. Since I went ot the boat over the weekend, I use ther steps and they are fine. I will do one last sanding befpre beginning the varnishing process.
    The Epoxy was looser than I anticipated and my efforts to get it to stay were halfway successful....I have about 1/4 inch to fill next time.
    I'll post photos later showing where I am now....
    Glyn, I may just take you up on that
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  14. #14
    Join Date
    Feb 2016
    Location
    Posts
    124
    So, the Epoxy was loose enough to spread over the wood as you can see in the photo. I will have to sand it all down. The steps are looking better and will soon be ready for varnish. It IS a hassle taking the steps back and forth to work on them...but its breeding some patience on my part, and will come in handy when I tackle the companionway hatch.
    Thank you all again for your comments and support.
ID:	20066   Click image for larger version.
Name:	top of steps.jpg
    Eric Gordon
    Dana Point, CA
    "Sea Star"
    Hull #721
  15. #15
    Join Date
    Oct 2012
    Location
    Los Angeles
    Posts
    3,919
    Blog Entries
    78
    Believe me when I say we are all in a learning process with boat jobs. Even though knowledge builds up over time, every new job is the first time, which separates us from professionals.
    Laminating epoxy is wrong in this case, since you're not laminating anything. It's runny and remains somewhat flexible. West System epoxy (there are other brands) is the general epoxy to use, and it can be thickened to a peanut-butter paste for filling using colloidal silica (very hard) or sawdust (sold for the purpose).
    It's what we would use to "glue" elements together. It can fill gaps, unlike glue.
Similar Threads
  1. Seeking advice on E32 mast step repair
    By tenders in forum Maintenance & Mechanical
    Last Post: 06-21-2018, 06:48 PM
  2. Have to repair my mast step/compression post--what tools do I need?
    By knoisewater in forum Maintenance & Mechanical
    Last Post: 05-24-2016, 03:36 PM
  3. Companionway hatch
    By john_keating in forum Maintenance & Mechanical
    Last Post: 07-15-2015, 01:59 PM
  4. Cargo shifting 3-step dock step
    By Sven in forum For Sale & Wanted
    Last Post: 05-10-2012, 06:45 PM
  5. Teak Companionway Hatch Repair
    By Dean in forum Maintenance & Mechanical
    Last Post: 12-23-2000, 01:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
