This is a classic "if it ain't broke" story. I had an old Stant radiator cap which I took into an auto parts store to get a replacement. I figured since I was cleaning the heat exchanger etc, might as well replace the cap. Have been losing coolant ever since through a steady drip drip drip as the engine comes to temperature. So I went to Hansen Marine and got a cap from them. It is Westerbeke part number 024306. I have also scrubbed the surfaces of the cap opening with scotchbrite to make sure there is no rough surface or corrosion. Still leaks. Any ideas?
Lee
Lee
