Kevin A Wright
Hey all,
I just finished upgrading the heat exchanger on the M25 in my '86 E35 mk3 to the 3" and moving up to a 3 blade prop. Now that my overheating issues are taken care of I'm moving on to the next question.
If I look in the manual my M25 should max out at about 3000rpm. But according to the engine panel tach, it maxes out at 2300 rpm. Is my tach out of whack or did some PO govern the engine down to keep it from overheating (with the old small heat exchanger it was always running about 185f even with the 2 blade prop)? Anyone out there with this same setup and what rpm's are you getting? Looking for ideas before I start tearing into things (again).
And yes Sean this is your old boat. So any history would be appreciated.
Kevin Wright
s/v Hydro Therapy
Kevin Wright
s/v Hydro Therapy
