Hi again-
My boat was repowered from an Atomic 4 to a Beta Marine D722 (20hp). When we took delivery of her last month, it was apparent that engine maintenance had fallen by the wayside-the oil was just about black (since changed), coolant needed topping (and likely flushing but haven't gotten around to that yet), and the alternator belt was worn and needed replacing (lots of black dust).
I've since changed the belt. Before I installed the new one, I took a steel brush to the pulleys to address what appeared to be minor rust. I've only run the engine a bit since I changed it (mainly due to waiting to get our tank polished-we had some dirty fuel that resulted in some stalling issues while sailing her back to our marina), but have already needed to re-tension the belt after probably not even an hour of run time. I'm also noticing some chafing on the outside edges of the belt and some more black dust.
Is this normal for a new belt (is there an "adjustment" period before it doesn't need re-tensioning)?
