I have a Ericson 32, 1987 which I've owned since 2002. Upon deciding to do a trip from Cape Cod to Florida via near shore/intracoastal in 2003, my mechanic suggested a 3 blade prop to replace the maxi prop the boat came with. I now have a very worn and pitted 13" 3 blade w/12 pitch that I'm trying to replace. I've narrowed my search to two Michigan propellers. Their MP3(which they recommended) or the Sailer 3 which seems to be slightly more streamlined. I do a lot of motoring between sailing opportunities but I still want to keep the drag down when I do sail. Can anybody help me from their experience or information?
My Yanmar 1GM is a bit underpowered for my E26, so I need to maximize what motoring performance I can get out of it with a good prop. The prop that came with the boat was a large, Dumbo-eared Michigan Wheel 3-blade. It worked quite well under power, giving me surprisingly good motoring performance considering my diminutive engine. But the drag from those blades: yikes!
A few months ago I replaced it with a Campbell Sailer 3 blade. (This is not to be confused with the Michigan prop you mentioned under a similar name.) This is sold by West by North Enterprises. The performance under power is equivalent, with the exception of reverse, which is a bit anemic compared to before. But reverse is good enough. As for under sail, since I don't race the boat I don't have an objective baseline against which to compare the difference. But I *know* it has to be better based on the surface area of the blades alone. Subjectively, it does seem better, especially in light air. I'd have to think I picked up around half a knot--but again, that's just a wild guess.
Maine Sail has done extensive testing on the Campbell Sailer prop here:
http://forums.sailboatowners.com/index.php?threads/prop-review-campbell-sailor.112587/ His recommendation influenced me significantly in my purchasing decision. I will also say that I was entirely satisfied with the tech support of the company that sells these.
I've attached pictures of both props so you can see the before and after.
