markvone
The frame and trim ring are white plastic. 18 screws clamp the inside trim ring to the frame. There is a foam weather-strip like gasket for (theoretical) sealing to the cabin side. The glazing is crazed so it's not glass. The max outside length is 28 1/8" and width is 8 3/8". The minimum cutout size is 27 1/16" and 7 1/8". Both of these are slightly larger than the Lewmar 4L/4R.
I removed the aft starboard one easily by removing the interior screws and pushing it out. The only thing holding it in was my exterior anti-leak tape job! The hull side cutout was shockingly precise by Ericson's standards so I suspect this is not original. The glazing is solid in the frame and the weather stripping is shot so my leaks are between the portlight and the cabinside. Since the glazing is crazed and I see no way to get it out of the frame to replace it, I'm probably looking at new portlights just to fix the crazing. I'd like to know who made these if we can figure it out.
Mark
Mark
