Hi,
Any experience out there on installing jacklines and/or padeyes on an E38?
I was going to do as follows:
1/4" Amsteel within 1" yellow nylon tubular webbing. One continuous length, with a SS thimble and locked Brummel on each end. Lash one end with 1/8" Amsteel to stanchion base on aft side of gate. Route webbing up along port side-deck, within the shrouds, up through the hole in the port bow cleat, across the bow and through the hole of the starboard bow cleat, then back down the starboard side deck, and finished with another lashing on the starboard side stanchion on the aft side of the gate.
It may be a little bit of a reach to click in from the cockpit, but it keeps you 6' from the end of the boat, which people recommend (just forward of the primary winches).
What about pad-eye locations in the cockpit? I don't want to be drilling holes everywhere, so want to locate them wisely and efficiently.
Mark
Mark
