Fuel fill hose, E 38
hodo
While spring cleaning, I found some small cracks in my fuel fill hose, near the tank. I need to replace it be fore I top off. Anyone know size and length? 1985 E 38.
Thanks, Harold and Jessie, S/V Mischief :devil: Maker
footrope
I'm going to the boat this morning and I should be able to get the diameter and estimate the length for you later today. It's still up in the yard and the aft part of the tank is uncovered.
Craig
footrope
The hose is Gates fuel hose with the numbers 4224 on it. I forgot to measure the OD before I had to leave. If the fuel deck fill is the same as the water deck fills the the hose is 1-1/2 inches ID. The length is hard to determine installed. I'd buy 8 feet to be sure to have enough.
It's still out at Delta. It'll be a year soon. The fuel filler hose is one of the few areas I haven't touched on this layup.
mkollerjr
I haven't measured my fuel fill hose, but I'm 99% certain it's 1-1/2" diameter. I'd guess 8' would be enough, based on recollection and without having measured that either.
Mark
hodo
Thanks, guys, off to fisheries tommorow. Craig are you at your boat tommorow? May stop by....
Harold
footrope
snip ... Craig are you at your boat tommorow? May stop by....
Harold
Harold,
No probably not, sorry. We have a repairman coming between 1 and 5 pm and I brought the new water heater home to start putting fittings on it in the morning. I bought a 6 gal Torrid round upright to replace the aged but reliable 12 gal Raritan. That'll be like 60 lb less in the stern.
Craig
hodo
Fill hose length
Fuel fill hose is in, Takes 7 feet, but buy 8', allows you to install it easier. P.S., The new trident hose is larger OD than the 1984 hose. Won't go through the Fill fitting opening.
Thanks, all.
Harold& Jessie, S/V Mischief :devil: Maker
hodo
Fuel Fill Hose
The hose is 1 1/2" ID. I inspected the vent hose, it looked great, so I reinstalled it. Don't overlook the grounding wire between the tank and fill neck. Enjoy. Hope you are thinner and more flexible than I....
I got Mine from Fisheries in Seattle. W.M. was pretty spendy. You can try a hyd. hose supplier also. They seem to stock it around here, anyway.
Harold
