I knew about the water coming down the inside of the mast but this was coming on the outside of the mast just under the wood trim of the headliner. I removed a sunbrella covering which protected the rubber mast seal and the rubber looked OK but when viewed from inside the cabin, I could see daylight through a section of the rubber where the leak was. The rubber was worn so thin in one spot that you could actually see daylight.
I bought a rubber mast boot that is slit, glued and clamped around the mast but it is too wet to do that work now. So as a quickie fix, I wrapped a sheet of 3 mil poly around the mast on top of the leaky rubber but when I test my fix with a hose, the leak was still there. I am going to check tomorrow but right now I think some of the bolts holding the collar onto the cabin roof are leaking. I am sure these are thru bolted with nuts and washers under the headliner, maybe even a backing plate if Ericson did things right.
But my problem is, and always has been, that the beautiful headliner hides the bolts. I removed the wood trim around the mast and how I will carefully remove the staples allowing me to get my hand behind the headliner to see if any bolts are loose. But I am afraid I will have to remove the collar completely and re bed it.
So again has anyone had to remove the collar. I will remove all the lines going to the collar, the main and jib halyards, main sheet and the reef lines, then see if the bolts are loose. Let you all know what I find out.
Our boat came with leaks under that nice-looking Kenyon vinyl boot. I found that the "boot" was intended to be mounted on the base of the spar before the spar was stepped. Fine for the initial owner and OK for a few years. Problem was that UV was deteriorating the material. In any case the yard sliced the boot down one side -- it could be reinstalled after the spar was in and the joint crudely covered with sealant.
The basic design, with the long clamp around the top and bottom of it was indeed clever, but when Kenyon went out of business the source of new mast boots (along with their nifty spreader covers!) vanished.
A friend who has a lot of ocean races on custom boats to his credit, told me to do "whatever it takes" including layers of sealant and plastic to stop all water.
Then cover it with a good-looking Sunbrella cover.
We did that a number of years ago and have never had a drop of water leak down the outside of the spar since.
About the teak collar inside... I took ours off and refinished it. Yard (or someone) had broken it in two anyway. I epoxied it together and then cut into two tidy halves. Still attached with a screw on each side. I varnished it and put a short ss pin on each end surface and a corresponding hole opposite each pin. That way when both halves are held up and pushed together, the screws are inserted and it looks very "finished".
Above our vinyl/fabric headliner is a plywood piece - with the nuts on bolts for the ss plate on top that carries the base turning blocks - surrounding the molded opening in the cabin top and while it has no rot, there was a lot of water staining from neglect of seepage by the first owner. That water seepage had migrated out each side under the fabric, corroding out the zipper pulls on each side (I have replaced them) and even allowing some water stains on the inside cabin sides.
One more thing: the track on the back should be well plugged with a lot sealant where it goes thru the deck.
Regards,
ps: prior thread with picture of boot cover.
http://www.ericsonyachts.org/infoexchange/showthread.php?7588-Mast-Boot-35-3
