Ideas for Cosmetic Improvement of Black Mast
bgary
Advanced Beginner
Anyone have experience with any of their brush-on primers?
No, but I had a number of places where, like you, I wanted to just spot-patch an area rather than taking it down to bare metal.
I had decent success spraying a small amount of the zinc-chromate primer into a plastic cup, and then dabbing it on with a small brush.
You may have to do some light sanding to remove any brush-marks, if the areas are in a place where the cosmetics would stick out, but... it works.
$.02
Bruce
bgary
Advanced Beginner
mmm, don't know. Might be fine, I just don't know.
In broad terms, zinc-chromate is what you want - it is an "etching" primer, which provides a good chemical bond between the aluminum and the paint.
My instinct is that the "aluminum black" might be a one-step solution, but might also interfere with paint if you (later) decided to paint over the area. It's effectively a way to chemically "anodize" the aluminum, not really a surface-prep.
$.02
mjsouleman
I am upgrading my boom Ericson 1983 30+
Paint
AirCraft Spruce: Zinc, Phosphate - Boom primer - $17.5 and PTI white engine enamel - $18.50
at the suggestion of another Ericson thread. Both are spray cans. I will be sanding to metal, applying the primer and then two coast of white enamel.
Lines:
At the same time, I am replacing lines:
Boom Length: 13 Feet
Starboard Reef line (3/8) - NESS518 GREEN: 26 + 13 (Sta-Set)
Port Reef Line (3/8) - NESS518 RED: 16 + 13 (Sta-Set)
out haul (rope) (5/16) - NESS16 WHITE/BLUE: 10+ 13 (Sta-Set)
topping lift (rope) (5/16) - NESS146BLACK: 5+ 13 (Sta-Set)
APS recommended the Sta-Set instead of the XLS as the XLS was being discontinued and they did not have the colors.
MJS
Thanks Bruce. I actually got a call in to a rep at Aircraft Spruce, but he was no help at all. He told me they have over 700 items in stock and he can't be familiar with them all. So I'm turning to my trusted EYO advisors.
