Results 1 to 6 of 6
Thread: Winterizing Fresh Water System
  1. #1
    Principal Partner
    Join Date
    Nov 2004
    Location
    Annapolis, MD
    Posts
    326
    We usually pour pink RV antifreeze in our water tanks and pump through to all faucets and shower head. But getting the pink stuff flushed out of the water tanks in the spring is a pain. I'd like to figure out a way to avoid putting antifreeze in water tanks but still get it into water lines and pump. I already have a bypass on the water heater so no pink stuff gets in there. Any suggestions appreciated!
    Laura Bertran
    Footloose, 1985 E35-3
    Annapolis, MD
  2. #2
    Principal Partner
    Join Date
    Mar 2006
    Location
    Winters, Boca Raton, Florida, Summers Glenview(Chicago) Illinois.
    Posts
    317
    Pink Stuff in the tanks....
    Laura: Did your routine once...including getting it in the hot water tank....UGH......
    Now, we run the pump until the tanks are empty....then open the inspection plates and sponge out the balance......Take off the hose on the "IN" fitting on the pump......put a hose on that fitting long enough to fit into a gallon jug, or a five gallon pail that you keep filling with the pink stuff until it runs very pink out of every outlet.....
    BTW....we also have a bypass on the hot water tank....
    I am sure there are other methods out there, but this is what we have come up with....and so far...so good.....
    Good Luck
    Mort Fligelman
    A Capella
    E35-3 1987
    Glenview, IL
  3. #3
    Principal Partner
    Join Date
    Nov 2004
    Location
    Annapolis, MD
    Posts
    326
    Simple Is Good!
    Thanks, Mort. Sounds like a winner! And if it works for you in Chicago, it ought to work well in Annapolis!
    Laura Bertran
    Annapolis, MD
  4. #4
    Join Date
    May 2016
    Location
    Lake Champlain, VT
    Posts
    105
    Between the pump and the tanks
    This is my first winter weatherizing on my own and I'm a little puzzled. Manual recommends dumping RV antifreeze into each tank but I also see complaints about getting the pink out in the spring. A friend with an E-35 has a little bypass next to one of his tanks under the settee and does the jug sucking from there, but I also see the recommendation to attach a hose at the pressure pump on this thread. Is there a best point of entry for a 32-3?
    1985 E32-3
    Universal M25
    Aylwin
    Lake Champlain, VT USA
  5. #5
    Principal Partner Afrakes's Avatar
    Join Date
    May 2009
    Location
    Port Kent , NY 0n Lake Champlain
    Posts
    616
    No Pink Stuff in the water system
    I disconnect the outlet on the water tank, the boiler valve on the water heater and let them drain into the bilge. Like Mort I open the inspection ports on the tank and sponge. Pump is unhooked and turned on to empty. All faucets are opened and I use compressed air to blow out the lines. Last year I didn't remove the system filter I have before the pump and even with applying compressed air water remained in it, froze and cracked the housing. This year it will be removed and stored inside out of the cold. I have a bypass set up between the engine cooling water thru hull and the fresh water pump for winterizing. I open the drain on the engine muffler and let that water drain to the bilge also. I replace the drain plug then I close the thru hull and open the bypass. I attach a hose to the bypass, the other end goes in a bucket with three gallons of eco friendly antifreeze and run the engine until pure antifreeze is coming out of the exhaust. Aren't you warm climate folks glad you don't have to go through this every year after a much too short sailing season.
    RebaGee gets hauled next Monday. The sails and boom have been removed. On her trailer she will go, the mast will come down and off to the shed she will go for another winter. A winter filled with all sorts of projects which we hope will be completed before she gets wet again next spring. There is the proper mast to rig, sails to be recut, new cushions to be made, etc.
    Al Frakes
    1987 E-28 Reba Gee
    Hull #663
    Port Kent, NY
  6. #6
    Join Date
    May 2016
    Location
    Lake Champlain, VT
    Posts
    105
    My Dog Has No Nose
    Actually, my tanks have no ports. Three tanks zero bypasses. I thought, heck, I will just dump pink in my bow tank that I rarely use. 4 gallons and thirty minutes of pressure water/foot pumping and Iím getting clear dribbles. And now itís starting to ooze into the bilge. No wonder I never i
    use that tank. Good thing itís not cold yet. Whatís that white stuff accumulating on deck? Noríeaster this weekend. Living the dream.
    1985 E32-3
    Universal M25
    Aylwin
Similar Threads
  1. Winterizing Hot Water Tank and M25XP On E35-3
    By Mort Fligelman in forum Maintenance & Mechanical
    Last Post: 09-03-2011, 06:46 AM
  2. Fresh Water Leak E-38
    By erobitaille in forum Maintenance & Mechanical
    Last Post: 05-08-2010, 09:24 AM
  3. Need assistance on fresh water system(s)
    By therapidone in forum Maintenance & Mechanical
    Last Post: 08-09-2006, 09:05 PM
  4. No (fresh) hot water
    By kevin81 in forum Maintenance & Mechanical
    Last Post: 01-30-2005, 12:39 PM
  5. Sean Engle's fresh water flush system
    By jreddington in forum Maintenance & Mechanical
    Last Post: 07-27-2001, 09:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
