Background:
I purchased a Ericson 1983 30+ in March or 2014.
Now that I look back, the broker kept suggesting I have the engine looked at... I should have known.
While replacing throttle and transmission cables, I removed the rusted out water heater.
Note: I reconnected the coolant lines so the coolant would loop.
Being excited about getting the boat back I went for an overnighter in 15-18 knots. When it was time to return, I was headed into the wind and tide in Chesapeake bay. Ended up running the engine for 3 hours to battle back to sheltered harbor.
The next day I tried to sail but the engine over heated.
I asked a mechanic to look at the engine and this is the response:
"I was at the boat this afternoon. cooling system held pressure when tested. you have oil leaks as you know with all the kitty litter under the engine. I ran the engine, there is a rapping noise coming from the front cylinder. I did a compression test. the front was 380 psi (slow getting there) the rear was 405 psi (achieved quickly). There is definitely something wrong with the front cylinder.
I did not do a service to the engine."
Mechanic suggested a repower and I am researching the Kubota Beta 16.
I feel like a idiot knowing that the coolant most likely had an air blockage and that having a little more knowledge would have saved me a big bill.
MJS
MJS
MJS
MJS
