Wanted: Barient 22 2-speed
footrope
I just found the mainshaft cracked on my Barient 22 halyard winch that mounts on the mast. If you've got parts or an entire 22 for sale, or maybe a Barient 23, I'd be interested. Thanks.
footrope
Thanks. I haven't looked at their website for quite a few years. I'll check them out.
footrope
Found a pair on eBay
Got a pair of 22 2-speeds off eBay for under $250. One of them should have a good mainshaft. The Arco quote for a new mainshaft was about $320 US.
Doing a little research, I discovered that the chrome-bronze drum from my 22 should be interchangeable with the aluminum alloy on the ones I bought. Ditto with the mainshaft.
cswim
Be careful. The aluminum might cause corrosion as the metals are dissimilar. Please check into this.
footrope
In this case the guts of the winches are all the same, regardless of what the drum is made of. So, swapping bronze for aluminum on these winches is not going to be a problem. Thanks for the concern, though.
