Can someone tell me how to go making my windows stop leaking?
A note on sealants: the right one is rarely at hand, and they're all expensive, and each has specific properties. It's a big topic.
Here's one of a million articles: http://www.boatus.com/magazine/2013/April/how-to-pick-the-right-sealant.asp
Personally I avoid silicone on boats--it doesn't work, and it leaves an invisible residue.
Just get some silicone remover.
There's a treatment of my "window" rebedding job here (some say there are no windows on boats, only ports, hatches, fixed lights). And others say "boat" should always be "yacht", and that all coversation about yachts should properly be in Dutch.
Also, you and others have mentioned that the holes for ports are always over-sized. Was wondering what you would think of filing the edges in a bit with epoxy putty to make the fit more snug? I'm thinking that it might be stronger and thus safer in the event that port ever got hit with a big wave; that is, it would be less likely stove in.
I was advised against using epoxy to build up the cutout because it was to rigid and would break up as the boat flexed.
Ericson cut the portlight openings with an axe (meaning not very precisely), but as long as there is enough material to provide a good mechanical connection between the portlight flanges, no worries.
In my opinion, Butyl is very handy but not for every job. I found Life Caulk much easier and natural and traditional to use for the big lights. It's easier, faster and fills gaps naturally (although it's not a certified gap-filler).
I have butyl all over my boat, mostly on small jobs like the hinges of cockpit locker lids or rebedded fittings. It's all still oozing. Yeah, Maine Sail instructs to tighten the fitting gradually, over several days, so most of the butyl will find its way into the right places, instead of just coming out the sides. However, in the real world, that is a tall order for every single small rebedding job you encounter.
So, butyl is easy and fast and cheap and you don't have to use a whole tube or break into a $25 caulking gun cartridge. But two weeks later, and two months later, you may be peeling off excess.
On big jobs I personally remain a caulking dude.
