Sprit envy
In the fall of '09, I was involved in an accident which broke my spinny pole in half, necessitating replacement. I had also been considering replacing my spinnaker since it was the original 20 year old chute which was showing some age. Given the need to invest in a new chute, and the new need to replace my pole, I did some research and decided on going Assy, with a deck mounted sprit. Several options are available, but I opted for the Sparcraft kit because it is easily removed, and retractable.
The stock Sparcraft alum extrusion only allowed a 2" extension beyond the stem.
I wanted to stick the sprit out there for cruising and racing (and take the PHRF hit), so I had Forte make a custom CF pole. Total cost of stock Sparcraft kit is about $800.00, another $750 for the Carbon Fiber pole. I also purchased a new chute ($2500) , and made some structural improvements underneath the bow fittings (which I was able to do myself). Running rigging mods (installation of the tack line) may also necessitate a clutch and fairlead eye (not yet installed in this picture).
The end result has been great. it offers a lot of power when racing, and is easy to cruise with my wife using a sock. Also, can be retracted when not in use allowing free access to the anchor locker.
Makes for a lot of fun, fast cruising, and for a modest 3 sec/mile hit, offers speed advantages when symetricals can't fly the chute at tight angles.
CTO
