Hello all,
I've read a lot on the forum so far about bent rudder stocks, but I haven't been able to find the exact information I am looking for.
We ran aground recently and fortunately made it out with only a jammed rudder. I jumped in the water, put a sail bag and line around the rudder just in case, and then dropped it in the water. The rudder was jammed against the hull. A friend had to hit the top of the stock with a hammer a few times before the rudder began to turn free and I could just pull and twist it out from under water. (The rudder floated, by the way; I've seen some back and forth about this.)
Now, the rudder stock came out with the brass bushing still on it near where the stock enters the glass. Until I saw a diagram of the rudder assembly found on this site, I thought that is how it's supposed to be.
The bushing is stuck on the stainless steel tube, and I am worried the metal is deformed so that even if I bend it back to the correct 90 degree angle it will still be stuck in the shaft and won't turn freely.
My question is:
How did the bushing function originally? Was it affixed in the bottom of the rudder shaft somehow and it ripped out when I dropped the rudder? Was it just tightly put into place without any material holding it in?
This was a really tragic incident, as I had just spent about $1000 dollars (parts and labor add up, even though I did it myself, as everyone knows) fixing the spreaders with some reinforcing doubler plates, a spreader bar, and new spreaders fabricated by Ballenger Spars. We had fresh running rigging, everything looked great, then we came out the south entrance of the Marina with a southerly wind and a strong incoming tide and the motor wouldn't start. By the time it was obvious that the motor option was no good, there was no room to maneuver and we drifted into the lee shore.
Any ideas about how to get back on the water cheaply? I've called Foss Foam and gotten a quote. It just seems too expensive to get a new rudder at this point. I have also been doing a big internet search and calling up lots of boat yards and salvage places to find a used one. Any pointers at all appreciated. So far it looks like finding a needle in a hay stack.
I'm located in Berkeley, CA.
My question is:
