Results 1 to 3 of 3
Thread: Securing a laminate cabin sole
  1. #1
    Contributing Member II
    Join Date
    Aug 2009
    Charleston, SC
    I have a laminate cabin sole that looks like the above picture. I had a leak in my head over the years and about a one foot section is not attached to the boat floor any more. The problem is is that the section that is not attached is in the middle of a long piece which is attached at both ends. To fix it I was thinking I could either rip up one side an then glue down (How does one rip out a section without damaging it), cut the material in a straight line and glue or lastly try and find a way to inject some glue under the loose material and then place a weight on top until it dried. Before I begin this project I thought I would ask for opinions.
  2. #2
    Principal Partner Tom Metzger's Avatar
    Join Date
    Oct 2002
    Clifton Park, NY
    Eric - Have you considered using bronze flat head screws, or stainless painted an appropriate shade of brown? It could save you from an ugly job.
    I won't tell if you don't.
    Tom Metzger
    E-34 Xanthus
  3. #3
    Principal Partner
    Join Date
    Jan 2006
    Wakefield, RI
    When you say laminate, do you mean a veneer lifting off the plywood floor or do you mean the entire floor is separating from the understructure of the hull? Either way you may me able to drill 1/8" holes if you can figure out where the supports are underneath, inject a slightly thickened epoxy and then put a heavy weight on it. That or screws, or cut out and re-bond. RT
    Rob Thomas
    Wakefield, RI
    1983 Ericson E38 "Ruby"
    "I purchased a boat because setting fire to $100 bills was not an efficient enough way to dispose of them...."
Similar Threads
  1. Cabin Sole-how best to remove old sole
    By tilwinter in forum Maintenance & Mechanical
    Last Post: 11-28-2014, 08:26 AM
  2. Wet Cabin Sole
    By richwilson in forum Maintenance & Mechanical
    Last Post: 10-28-2009, 06:42 PM
  3. Cover cabintop sides in main cabin with laminate?
    By cruis-n in forum Maintenance & Mechanical
    Last Post: 02-05-2003, 04:06 PM
  4. Laminate for topside walls in main cabin
    Last Post: 01-09-2003, 06:13 PM
  5. Cabin sole
    By Blair in forum Maintenance & Mechanical
    Last Post: 11-17-2002, 11:11 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
