E 23
What I have for a wiring diagram is for a E 23 -II. And it bears little resemblence to the wiring in my E 23 - II.. The Battery shown in the Stbd. cockpit locker is CL ubser the companionway steps. The showr power breaker shown on stbd side are mounted to port. The three 11oV AC outlets are ONE adjacent to the breaker to Port.However th Battery Switch and six fuse / switch panel are on the aft Stbd Bulkhead, as shown.
The switches / fuses
Running lights. Port, starbord and stern lights White wire Black negative return.
Bow Light. Brown wire.
Cabin Lights (3) Red wire 12 V flouresent Stbd, port, and an incondesent bu potty.
Compass / Spreader Light Yellow
Accessory / Masthead light Blue
My mast head is #3 vice Bow light and so marked.
the bottom two are marked Accessory/
The wires for the Masthead and (Non existant) Spreader lights run down through the bildge { A NO NO}
Apparently a Previous owner had an Alternator equiped outboard, as two bolts through the port cockpit locker bulkhead had battery cables to the battery.
The drawing is a copy of a copy of a copy and is semi legable, as well as incorrect.
Have Fun!
