Results 1 to 5 of 5
Thread: Wiring a windlass....
  1. #1
    Principal Partner
    Join Date
    Jan 2006
    Wakefield, RI
    Hello All,
    Currently working on a Maxwell windlass install. The schematics and instructions speak of wiring directly to the battery bank, but there is no prohibition of wiring through the battery selector switch..... Is it possible or even prudent to wire through the battery selector switch? It would seem to make sense to do so. It would make sure the power to the windlass was off when the whole boat is shut down. Is this warranted or a possible problem with the failure of the selector switch? The windlass has a 135amp inline CB so I think the selector switch will handle that no problem. The cables from the bank to the selector switch are 4/0 cable, way huge, so current is not a problem. What say the crowd? RT
    Rob Thomas
    Wakefield, RI
    1983 Ericson E38 "Ruby"
    "I purchased a boat because setting fire to $100 bills was not an efficient enough way to dispose of them...."
  2. #2
    Join Date
    Dec 2000
    Santa Monica CA
    Wiring your windlass.
    Rob, You could still shut everything off when leaving the boat without wiring the windlass through your battery selector switch by doing what I did (and I think what most everyone else does). My 1/0 cables lead directly from my Blue Sea power posts adjacent to my battery bank. I have a short cable from the positive post to a 150amp Blue Sea breaker. Power to my Ideal MCW windlass is normally off at the breaker and I would only energize the windlass if I planned to use it. The other benefit of having the power switched off is that I can freely walk around the foredeck without regard for spinning the windlass up or down if I happen to step on one of the two foot switches. My opinion, worth less than Loren's 1 cent. Glyn Judson, E31 hull #55, Marina del Rey CA.
  3. #3
    Principal Partner
    Join Date
    Nov 2004
    Annapolis, MD
    Wired To Battery
    I just got done installing a Maxwell windlass last weekend and followed the schematic by running the positive cable to the battery rather than to the selector switch. In my case, going to the selector would have added several feet in cable length and keeping the wire run as short as possible is a real plus. As Glyn points out, the Maxwell circuit breaker in the positive cable can be used to de-energize the windlass circuit without shutting off the house batteries. I also installed the Quuick remote control which I'll use instead of foot switches, couldn't bring myself to cut more big holes in my boat! Everything seems to be working and turning in the right direction! I just ordered the rode and chain for the new windlass and can't wait to try it!
    Laura Bertran
    Footloose, 1985 E35-3
    Annapolis, MD
  4. #4
    Join Date
    Apr 2012
    Port Townsend, WA
    Proper windlass installation
    Hey RT, your Maxwell instructions should show a diagram exactly like what libertran and glyn are describing. Always keep the cable run from the battery to the circuit breaker as short as possible, because a short-circuit here will definately cause a fire, use chafe protection if necessary. Athough I have seen windlasses wired to battery switches, I don't advise it, it adds more connections thus more possibilties for problems later on - connections can come loose and burn. Be sure to use the proper Blue Seas cable cap to cover your cable terminals on the back of the circuit breaker, solenoid and on the windlass. One more thing, consider placing an inline fuse in the positive wire the goes from the solenoid to the footswitch or remote plug (a short circuit here will not trip the 100-150amp windlass circuit breaker). And if your windlass is exposed to the chainlocker (read wet), then give everything a good spray with CorrosionX or a similar product. Have fun!
  5. #5
    Not the newest member Greg Ross's Avatar
    Join Date
    Nov 2006
    South Melville, PEI
    Windlass installation
    I opted to install a circuit breaker immediately adjacent to the "Engine Start Bank" since the engine will be running any time the windlass (originally installed Capstan) is running. The circuit breaker provides protection to everything between the CB (obviously) and the Windlass. Cables were run inside hose for chafe protection for the areas of the installation where I thought there could be exposure to external loads, etc.
    I ran those two cables up to the V-Berth void space where I created a mini power center/ pair of bus bars. The solinoid activated by the (covered) foot switch is located here and that secondary switch circuit is energized from this point as well. On deck I experimented with tailing rope looped around the capstan to determine where best to locate the foot switch. The location somewhat aft from the Capstan required a nominal bit of challenge on the I-31 to feed the switch wires over top of the rope locker bulkhead above the ceiling vinyl.
    Three images give you some idea of what was involved. The Mustang Capstan is coming off the boat in favour now of a vertical Ideal Windlass (all bronze Loren) c/w 275' of 5/16" chain.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	U-S Mustang.jpg
ID:	10936   Click image for larger version.
ID:	10937   Click image for larger version.
ID:	10938   Click image for larger version.
Name:	Hull _63, Ideal MCW _1RR.jpg
    Greg Ross
    Independence 31
    Hull No. 63
    Charlottetown, PEI
    If you come to a fork in the road, take it.
    ~Yogi Berra
Similar Threads
  1. E38 with Windlass
    By u079721 in forum Maintenance & Mechanical
    Last Post: 09-26-2010, 08:28 AM
  2. E34 Windlass Wiring
    By Erich in forum Maintenance & Mechanical
    Last Post: 08-28-2007, 08:41 PM
  3. windlass
    By david henry in forum Maintenance & Mechanical
    Last Post: 08-18-2007, 09:13 AM
  4. E38 Windlass
    By Captron in forum Cruising & Racing
    Last Post: 02-08-2007, 05:05 AM
  5. The Right Windlass
    By enrique in forum Maintenance & Mechanical
    Last Post: 07-23-2003, 01:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
