Brookelise
Has anyone here rigged their Ericson 34 or 38 for an asymmetrical spinnaker? The asymmetrical spinnaker is flown without a pole, and the question is: How did you rig the spinnaker tack block for the tack downhaul at the bow? Some suggest attaching the tack block to the anchor roller--for example with the pin in the anchor roller. The tack downhaul now runs from the tack, forward of the forestay, down to the spinnaker tack block and aft to the cockpit. Second, how did you rig the blocks for the sheets? The outer tracks by the toerail don't go far enough aft, and moreover, the blocks don't articulate (swivel) for sheet control. Some suggest attaching blocks to the stern cleats, using line. What kind of blocks did you get, and how did you attach them?
