Sven
Seglare
Maybe it wasn't all my fault ?
If you use the "Image" button to insert an image and then click on use remote URL and copy into a local copy (or words to that effect) you end up with a zero reference when you go to save. I retried several times to have picasa images referenced and copied into Sean's site and got the same result every time I tried. Maybe it doesn't like the https reference, didn't check that.
I reposted using the basic uploader function instead.
-Sven
-Sven
