The throttle on my e-29 (1972) is slipping. When I power up over 2000 rpm, it will slip back and settle at around 2000 rpm. Is this a simple adjustment? Have not had the boat very long and I am not sure where the adjustment should be made. Engine is a Universal M3-20. Is the adjustment on the inside mechanism, on the lever itself (there appears to be an access hole under the throttle lever for an allen key) or is it at the engine where the cable ends.
Much appreciated.
Paul.
Much appreciated.
Paul.
