fixntheboat
Anyone know the Manufacture of the spar and or spreaders..need to replace one if not all spreaders...ends are corroded on and base is cracked..
You might want to checkout Doug's post and start on post#24 https://ericsonyachts.org/ie/threads/e27-broken-spreader-bracket.8979/page-2I bought mine from Ballenger. It's a thru bar system, supposed to be very strong. I haven't installed it yet because it's a bit out of my wheel house to cut into the mast.
I was worried about this too and it took me quite awhile to get up the nerve to cut into the mast. But once I did, it wasn't difficult or complicated, just finicky and time consuming. Research, plan and then work carefully and methodically. Measure 6 times! Cut things a little short and work into the final dimensions with a mini file set. Round the corners of the thru-bar cutout with a very small round file to prevent stress cracks. I had Brian Toss review this work plan as part of a rigging inspection/consult since I replaced the chainplates as well and he said it was a good repair plan. In fact he recommended that I switch from rivets to screws for the repair plates which I did. The boat is no longer mine, but is still actively sailed by a friend and the spreaders are solid as a rock ten years on.it's a bit out of my wheel house to cut into the mast.
This is super helpful, thank you!You might want to checkout Doug's post and start on post#24 https://ericsonyachts.org/ie/threads/e27-broken-spreader-bracket.8979/page-2
I
Need to get the cobwebs out of my memory banks, BUT - MANY - years ago our spreader ends were corroded badly on our ‘73 E-32.Anyone know the Manufacture of the spar and or spreaders..need to replace one if not all spreaders...ends are corroded on and base is cracked..
I’ve still got our mast apart and stored on a rack yet so can get you a couple photos no problem.I'm need to replace lost speader base, I would like to see pics & know more.
